Results 1 to 10 of 13
Thread: Replacing diesel filer
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default Replacing diesel filer
    when i change my diesel filter is it ok to put some fuel treatment in the filter with some diesel? It wont do any damage will it?
    On the dti is the filer at the back of the engine to the right?
    Oct 2009
    Sandwell
    is the part number for the filter for the 2.0dti 13224128?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by chris1804 View Post
    Or to the left, depends on where you live
    As for the fuel treatment...nothing damages a DTi
    dont stick fuel treatment in the filter housing , that would just mean getting a really concentrated treatment for the first few miles
    your better off filling the housing with pure clean diesel a,d adding the treatment to a full tank of fuel
    Oct 2009
    Sandwell
    gonna take a picture to engine bay tonight so if somebody can point it out for me that would be gr8. Tryin to service car myself ready for mot next month.
    look at engine from the front of the car , at either the back left or right attached to the bulkhead will be a round plastic thing with 2 plastic pipes going to it , it also has an electrical connection going to it and on the top is a torx screw
    if you undo the scre and remove it you can then lift the top of the filter housing off ,
    then remove the filter elemn from inside ( you will spill some diesel here )
    put new element in , replace lost diesel , replace filter housing top , retighten torx screw
    then turn the car over till it starts
    if it cuts out keep trying it as there could be some air in the system
    bobs your uncle , one changed fuel filter
    Oct 2009
    Sandwell
    Quote Originally Posted by marktaylor View Post
    cheers bud will give it ago ill have to get me a diesel can first then
    East Midlands
    Don't forget to replace the rubber washers that come with the new filter.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Buy yourself a syringe, it makes filling the filter housing so much easier and keep your foot to the floor for re-starting
    Oct 2009
    Sandwell
    is tis the correct filter for the 2.0dti? this is what my motor shop gave me, because on ebay they look different, (ive got the seals)
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. K&N panel filer????
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 14th January 2010, 08:30
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
