Thread: Swirl Rod Linkage
    Jan 2010
    wirral
    Default Swirl Rod Linkage
    Hi all.....some help needed please
    Found my swirl valve rod lying on top of inlet manifold
    I fiddled about and managed to replace it. I know this is not a permanant fix.
    I am going to attempt the DIY fix as detailed on here as I have not got £500+ to have inlet manifold replaced at the moment!!
    I have question.....when the swirl rod linkage is correctly located, should I be able to see any movement in it while the car is stationary?? ie, I got my mate to give it some revs and I looked at the rod/swirl holes???
    Secondly, on re-locating the rod, I took the car for a run, got the lovely spanner light and upon reading the code I got P1106-62. Is this because the actuator has felt resistance, possibly due to a build up of crap in the swirl pots???
    It may just have been "all in my head" but the car seemed to pull a bit smoother in the lower gears during this test run, despite the spanner light being lit, and also I think there was power over a greater rev range (1800-4500).
    Please folks, any advice will be appreciated as I'm at my wits end.
    Regular Member bunsen1's Avatar
    suffolk
    it will move when revved,i belive if you rev to 3k you should see it move, 3rd pot will show movement without the rod on, and all with rod on
    with me i put the rod on and it didnt move, i went for a drive and got limp home mode as i beleive the 3rd valve was showing a problem as it was restricted, i put this down to the valves being shot and full of gunk, if your valves have play i.e. left,right,up,down and coming up higher than the seating i think that will cause to much resistance for it to work properly as the will be losse and jingling around everywhere, or maybe the 4 valves are not in the correct position for it to turn properly, i.e 3 are placed right and one is not
    best bet is when you can afford it,replace it im afraid
    Jan 2010
    wirral
    cheers bunsen for the reply, i did rev it but not sure it hit the 3k mark, as i say, i had only placed the rod back on and not actually done the diy tap washer type repair. There is a fair bit of play in them and i know, ultimately, the manifold must be changed. I am gong to try my luck with the local vaux dealer, as some other members have, even though the cars covered 85k. You never know....even if they offered to pay half I'd be quite happy. In my favour, it does have a full main dealer service history so i'll let u all know the outcome!!
    suffolk
    i tried but as my car was over 5yrs ols( 5yrs 6m ths) and over 100,00miles (102.000)
    i got told no, so depends what year and mileage mate
    Jan 2010
    wirral
    Yeah, just been there now, just asked nicely if there was any chance of maybe meeting me half way on the costs. They say that in order for me to lodge any claim of this nature, THEY must first diagnose the fault. I told them it was not that tricky as the swirl valve linkage was lying face down on top of the manifold, clearly detatched from its correct position. They want me to pay the diagnostic fee (£90.00) before they'll look into paying anything towards it.
    Oh and I also mentioned it was a well documented design fault, they said it is not a design fault as no updated/improved manifold has ever been produced.
    I'm sure I have read somewhere that the design was changed somewhere around 2006/7.
    Anyway, the linkage is now in my kitchen undergoing the DIY "screw-cap" repair, see how it goes!!!!!!!!!
    suffolk
    there is a modified or at least updated one as i and many others have one, the rod is held on by a more solid plastic,
    Jan 2010
    wirral
    cheers for that, i'll be making damn sure i get that one, its not the kind of bill I want to paying very often!!
  1. Swirl linkage advice please?
    By Gerdo3 in forum Engine & Drivetrain
    Last Post: 10th April 2012, 12:52
  2. Swirl flaps Linkage Rod
    Last Post: 3rd August 2010, 21:46
  3. EML was on now off...could it be swirl valve linkage
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2010, 09:14
  4. Swirl flap linkage fallen off but managed to bodge it! (I hope!)
    By jrwilshire2003 in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 22:42
  5. Swirl Flap Linkage Rod 'Cheap' Fix
    Last Post: 1st April 2009, 20:58
