Results 1 to 3 of 3
Thread: URGENT - Identification Required
    Bristol
    Default URGENT - Identification Required
    Hi all,
    Sorry for the urgent nature of this message, but I'm having engine trouble as detailed here: http://www.vectra-c.com/forum/showthread.php?t=114020 and I'm (supposed) driving the car to Germany on Sunday.
    It has been into the garage for 2 days where they claim to have cleaned the EGR and throttle body, even though I pointed out the parts below as the problem.
    What I need to know is:
    a) What is the part in the red box?
    b) It is controlled by one of the vacuum pumps in the green box (close up in second pic) - WHAT SENSOR(S) CONTROLS THESE?!
    I can swap the vacuum lines and connectors between the pumps and it makes no difference, still get the same problem, so I figure it must be whatever sensor is controlling the vacuum pump and therefore the part in the red box (normally connected to the pump on the right in the photo).
    When the engine starts dropping, I can see the part in the red box pulling all the way in and then it releases as the engine is about to cut out, sometimes not quickly enough and it does cut out.
    I can also simulate the problem if I disconnect the vacuum line and move the level by hand.
    Please help quickly!!
    Adam
    north east
    Im taking a guess the engine is a 2.0 dti, in which case your looking in the wrong place you most likely need a new crank shaft sensor.
    Is the fault only happening when hot ? is the radiator light coming on while running if so id say its 90% likely the crank shaft sensor is your fault.
    Bristol
    It's the 2.2 DTI.
    It's sounds the same as post 14 on this thread: http://www.vectra-c.com/forum/showthread.php?t=89343
    Is a throttle body normally held in stock at the dealer or does it have to be ordered?
  1. Urgent help required.
    By floppus in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 11:50
  2. Goodridge hose identification required
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2011, 21:04
  3. Oh Man, what have I done??? Urgent help required!
    By Nav-Man in forum Petrol Engine related
    Last Post: 2nd May 2010, 21:48
  4. Trim Panel Style Identification Required
    By Fireyfella in forum Styling
    Last Post: 29th November 2009, 21:37
  5. urgent help required
    By sulky_uk in forum General Chat
    Last Post: 22nd February 2007, 18:55
