Results 1 to 10 of 15
Thread: Car Going In
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Car Going In
    Got the car going to vx again with the same prob!...
    gearbox is very notchy and not engaging smoothly...had it in several times for gearbox linkage but somehow i think the problem is not that if it keeps happening!..also might ask them to look at my suspension as it doesnt seem to be handling very well at the mo...seems very unstable...any ideas? tyres are fine..but I am getting a knocking noise which is doing my head in...vx said noisy tyres last time with uneven wear..!!
    they also are going to fit some sort of cables to the gearbox that have been found to be faulty...any idea what they are or what they do?
    Give em hell Martin...
    Jul 2006
    liverpool
    i have a knocking noise when i brake, vx have sed it is the spare wheel knocking on the post where i have to screw it down, as for the gearbox, i have the same problem, but its not as bad as yours, only happens when i cane my car. have too stop doing that haha
    would do, only it is a different garage since we moved...second time it has been in at this garage and thats where they found the problem..somehow I think the clutch has someting to do with it...could be wrong though...am having to double clutch to get it to engage correctly
    Apr 2006
    Kent
    I have the notchy problem but only when it is cold. Took it into VXL and they said nothing wrong with it!
    Seems to me that this is a common problem that needs to be addressed! As soon as the warranty runs out were knackerd its out our own pocket!
    Mileage : 000
    I think the cables you are on about Dwabo are for the gear changeing, It could be possible that they have stretched, that may be why you have notchy gear changing, just a thought though, But I hope they get it sorted for you as soon as posible..
    Regular Member Harry's Avatar
    Uxbridge, London
    Quote Originally Posted by Martyn21
    I have the notchy problem but only when it is cold. Took it into VXL and they said nothing wrong with it!!
    aren't Vectras notorious for having notchy gearboxes? especially the low gears. it's just the way they are - mine is the same.
    unless you're having trouble actually engaging gears.
    Apr 2006
    Kent
    Maybe your right but every now and then when cold going from 1st to 2nd it can be a but dodgy. Once warmed up no problems?
    Quote Originally Posted by Dwabo
    get them to check the antiroll bar links and bushes...this problem is as old as the hills and they'll know about it...
