Thread: Brake wear sensors.
    Nov 2009
    Norfolk
    Default Brake wear sensors.
    I have had the brake wear indication on since I got the car.
    Finally want to get rid of it!
    Should there be a brake wear sensor on bath sides at the front or just on the one side?
    My Signum only has one fitted on the drivers side....???
    All of the previous Vauxhalls I have owned have had one on each front wheel.
    I have checked the pads and they are fine, so it looks like the previous owner couldn't be bothered to sort the sensors.
    Northampton, UK
    Mine only has one on the passengers side. Changed it today. Cost £10.80 from the dealers - part number 24427919
    Nov 2009
    Norfolk
    Quote Originally Posted by n_hudson View Post
    Will have to check, but sure mines on the drivers side!?
    Northampton, UK
    There's also the ABS sensor wire on each side.
    Brake wear sensor is only on one side - nearside as said above.
    Nov 2009
    Norfolk
    I'll have to get down to Vauxhall and get a new 'un then, may as well order a TC switch while I'm there.
    Regular Member kev77's Avatar
    nottingham
    Just cut the two wires and bridge them together tadar no more light
    Nov 2009
    Norfolk
    Quote Originally Posted by kev77 View Post
    i've done that on other Vauxhalls, but would like to sort it properly for once.
    Apr 2008
    Burton on Trent
    Mine only has them on the one side.
  1. Brake Pad Wear Sensors
    By MadTogger in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 10:25
  2. brake pad wear sensors?
    By marwen in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2011, 12:01
  3. Brake Wear Sensors?
    By Danger_MouseUK in forum Handling & Braking
    Last Post: 23rd May 2011, 18:33
  4. Brake Pad Wear Indicator
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2007, 19:51
  5. pad wear sensors
    By hagga in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2007, 21:19
