Results 1 to 10 of 13
Thread: t8919g dvd player problem.
    Jul 2010
    finland
    Default t8919g dvd player problem.
    hi. my car is vectra c 2008 z19d. with climate control and after installation of this unit, I lost the climate icons from the Gid.Is there any solution? everything else is working.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    that was a first never heard about that.. but you can wire the climate control straghit to the GID..
    (is you climatecontrol working at all?)
    Jul 2010
    finland
    Quote Originally Posted by kenp View Post
    climatecontrol is working but the gid did not show any information about climate control. i can not put air conditioning in the menu on or of. sometimes the climate icons flash on the gid.
    Engine : 2.2 Direct
    That sounds like a dodgy connection.. theres 2 wires going from the Climatecontrol to the GID.. (2 can-bus wires) that shows the info on the screen..
    Jul 2010
    finland
    when turn the ignition on the climate icons show about second then disappears.
    the player should be plug and play.
    Engine : 2.2 Direct
    Definatly can-bus related.. maby it actually show a error if you get a codereader on it..
    But would be a pain to locate the maby dodgy connection..
    Jul 2010
    finland
    did you mean troublecodes? is the player can-bus decoder wires wrong??
    Engine : 2.2 Direct
    yes that what i mean.
    it could be related to the radio (one way to check is disconnect it, if it works again then it is the radio)
    Jul 2010
    finland
    the gid is working without player. i can read troublecodes tomorrow.
    Engine : 2.2 Direct
    so when radio removed the ECC shows back on the GID? then it is your radio..
  1. dvd player
    By daddyjay in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2011, 18:54
  2. CD Player
    By cmishua in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2011, 19:14
  3. Problem with my new (chinese) 2DIN dvd-player
    By hudu79 in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 00:55
  4. Display & cd player problem - help please
    By alexander08 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2010, 17:35
  5. 04 plate CD player problem.
    By Keil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2009, 09:52
