Results 1 to 3 of 3
Thread: Help! Exhaust light / Judder???
    Jan 2010
    Glasgow
    confused Help! Exhaust light / Judder???
    hey
    looking for some help advice...
    (got a Sig 2.2 direct 2004)
    took the car out earlier this evening and drove about 40miles, no issues...
    but on way back as soon as I started the car it didn't sound right - driving in 1st / 2nd gear it was juddering a fair bit. The car has never done this before.
    I stopped car, re-started and it was still the same - noticed the car exhaust / emissions light was on?
    was able to nurse car home, had to high-rev through gears to keep it going but it was definitely lacking power the whole way...
    any ideas?
    It's going back to garage tomorrow- only 2 months since the chain snapped which was really, really expensive to fix : (
    cheers !
    Derby
    Could be a cylinder mis-fire. I had the same problem.
    The engine on my car had been valeted and water had dripped down into the spark plugs, causing 2 of them to short across. A new set of plugs and a clean up under the coil pack sorted it out a treat! I hope you get it sorted easily - altough to be sure of the problem you need to do a diagnosis and get the codes read.
    Good luck
    Jan 2010
    Glasgow
    ...thanks for the reply.
    Unfortunately it's been checked and the garage say it's the fuel pump, which will be over £500 to replace : (
    after spending approx £2K in the last couple of months fixing it after the timeing chain snapped and getting it serviced this is the last straw, i think it'll be getting traded it - sick of spending money on it
  1. 'Exhaust' light on!
    By cammy3000 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 21:09
  2. 3.0 V6, judder under light load
    By g1jkb in forum Engine & Drivetrain
    Last Post: 24th May 2010, 06:23
  3. Spanner light 5 times now exhaust gas light
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2009, 01:12
  4. Exhaust gas light
    By dans6490 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2009, 21:02
  5. Exhaust emmisions light
    By lcirillo in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 13:37
