Thread: Anti freeze
    Default Anti freeze
    Hi, I noticed my coolant needed topping up and poured some anti freeze in that i had in the garage ( vx stuff ) but as it went in it was blue, s**t, only about a cupful went in, so i shot up to the dealers got the right stuff ( pink ) emptied the header tank and filled with good stuff, will the blue mixing with the pink do any damage? Ta
    Mileage : 000
    I wouldn,t have thought so, not with the little amount you put in.I can not remember what the difference in the colours means, one may be long life but I am not sure, I dare say someone will put us right.
    They also told me you dont mix it with water anymore, just pour it straight in, is that right?
    Mileage : 000
    If you do not mix it with water the strenght will go up, so next time it is low put some water on its own to keep the correct balence, I quite often just put the antifreeze in on it,s own.On my wifes Vectra B I change the antifreeze in that every three years, I must find out the interval for my Vectra C.
    ps I wonder if the antifreeze is now "ready mixed" that may be why they say you don,t need to mix it with water. some one may be able to enlighten us on that one as I have not heard that before.
    Cheers Ed.
    mixing the two will not cause damage..so draining the header tank and re-filling like you did will be fine..the concentration of the blue will be minimal..
    When i obtained the red longlife coolant for spikey it came un-diluted from VX...50:50 mix with water for max protection..
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    I've got some GM branded pink antifreeze from a main dealer - it's ready mixed so no need to dilute.
    It's better, if more pricey, that way because one MB specialist I used to use for a Merc I had years ago reckoned it was the tap water mixed with concentrated Antifreeze that rotted out radiators.
    However, it does mean you have to buy the stuff from a main dealer to keep the correct Antifreeze in your engine when topping up and you can't share the same bottle between vehicles of different makes
    Marc100, it only cost £2.70 a litre, and he said you can use it in anything
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    £2.70 you cant beat that price..........
    Nov 2005
    Berks
    You're probably right but personally I'd still be wary about putting it in SWMBO's Toyota just in case the formulation is different.
    GM ready mixed is more expensive than Holts concentrate from a motor factors though.
  1. anti freeze help
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 22:58
  2. How much anti freeze?
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 13:58
  3. anti freeze help please
    By amir2300 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th January 2012, 01:02
  4. Anti-Freeze
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2005, 21:47
