Results 1 to 10 of 13
Thread: Hesitation help
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Default Hesitation help
    Hi I am new to the forum, I have a 54 plate SRi CDTI. When between 1800 and 2000 RPM I seem to have a slight hesitation, especially when in 3rd gear. Apart from this it runs very smoothly. It has been serviced recently. Someone mentioned that if I de-restrict the air box & put in a different panel filter it may get rid of this? Can anyone shed any light? Regards
    Jul 2010
    Skipton
    Hi, can anyone help?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    is it just a lazy spot or a short on/off snap(blip) of power?
    Jul 2010
    Skipton
    Quote Originally Posted by the-wizard View Post
    Best way to describe it is it feels like its about to cut out a bit jerky then as soon as in higher revs it goes.
    Jul 2010
    Skipton
    Can anyone help?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    This sounds like either 3rd injector issue or an EGR sticking, both of these can cause this jerkyness - and both are cheap to remedy (3rd injector loom = £13 and a can of carb cleaner to clean out the EGR).
    Regular Member pugs,signum's Avatar
    swansea
    plus give boost sensor a clean!
    try new fuel filter along with some redex injector cleaner,
    New air filter and do airbox mod
    try a new airmass meter if all above fails
    Regular Member crespo's Avatar
    Bournemouth
    That is 150% your MAF. Unplug it and go for a drive, if your flat spot goes you know its the MAF. Which i can almost guarantee it is. Unless you have neglected to service the car in which case it could be a dirty fuel filter. but then your car would splutter throughout the rev range not just at 1800 rpm.
    Jul 2010
    Skipton
    If it is the MAF how expensive is it to replace?
    Bournemouth
    Quote Originally Posted by ONEMINUTESILENCE View Post
    Between 70 and 100 quid depending on where you get it. They can sometimes be cleaned though with carb cleaner. when you get a chance unplug the MAF tomorrow and just take the car for a drive. If the hesitation goes you know its the MAF. Its free to do and wont harm the car. If it turns out to be the MAF report back and i will talk you through how to clean it. Be carefull though because if you use a cotton wool bud or touch the sensor with anything you could kill it completely. I just spray mine with carb cleaner then rinse it with warm water and let it dry. Then pop it back on.
    You can find the MAF located on the tubing coming from the air filter box.
  1. 2.0T Hesitation
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 8th May 2012, 12:48
  2. Hesitation please help??
    By sowter28 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 17:43
  3. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  4. Hesitation
    By Deadman in forum Engine & Drivetrain
    Last Post: 5th July 2008, 18:40
  5. hesitation
    By pogo in forum Engine & Drivetrain
    Last Post: 26th March 2006, 21:06
