Results 1 to 10 of 13
Thread: can SOMEONE help with knocking...PLEASE
    Jul 2010
    somerset
    Default can SOMEONE help with knocking...PLEASE
    Hi....i have a signum 1.9cdti 150 '05...for quite a while now i have had knocking at drivers front wheel area....sometimes i can drive over speed bumps and not hear it, yet another i can drive over the tiniest ripple in the road and i get this horrible metalic knock from the front (sometimes i am starting to hear it from the left side too)...the thing is that i have had it looked at 3 times (2 different garages) and it has not long gone through the MOT...no one can find the problem ''it all looks fine''.....i am worried that the only way to to rectify the problem is to wait for a wheel to fall off...but i dont want that as i also tow a caravan....i have also had the arb drop arms off and they seem ok....anyone had a similar problem...any ideas??
    Oct 2007
    Shropshire
    Mine squeaks all the time. I think it started like yours, just over ripples but now does it over speed bumps, pot holes etc...
    Like you noone can find a problem. There is no play anywhere and the springs are not broken. I wouldn't worry too much, just keep checking for play. Mine passed its MOT like this.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    try your ARB bushes and droplinks, is it a crunch noise? my arb bushes looked ok so i didnt change them but i still had the sound so i changed them and its all fine for now
    Full Member Big Sig's Avatar
    The rad mounts used to cause this too. Not sure if they revised the design so worth a look.
    Regular Member connery-sri's Avatar
    Basildon, Essex
    mine was due to broken spring and drop links.
    Jul 2010
    somerset
    springs are both ok
    West
    drop links as said, also check the strut top bearings
    Regular Member Jason H's Avatar
    Norwich, Norfolk
    Mine sometimes gives off a metallic 'ping' from the front if i go over speed humps or a very uneven surface. I NEVER go fast over these and have checked for anything amiss but found nothing.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Possibly brake pads rattling in the carrier. If it is this you wont hear it when your are braking.
    Regular Member crespo's Avatar
    Bournemouth
    ARB bushes, Drop links and also check your Exhaust mounts have not snapped off like on my car causing a clunk from the front every now and again.
  1. Very odd knocking
    Last Post: 4th August 2012, 09:27
  2. knocking
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2011, 00:29
  3. Knocking from under the car.?????
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 08:40
  4. Knocking from car?
    By ectraz in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2009, 14:52
  5. still knocking
    By adfrodsham in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2009, 10:34
