Thread: Op-Com 'cannot communicate with ECM'
    Nov 2009
    surrey
    Default Op-Com 'cannot communicate with ECM'
    Hi everyone,
    I have a new opcom V2.
    Freshly installed win7 laptop no other software except opcom.
    Software installed, and installed the drivers from the drivers folder.
    Ran test interface and updated to V1.39. and now tests all ok.
    When running diagnostics to the car ( vectra C 2005 ) all I get is a click and 'there is no communication with the ECM'
    I'm stuck, any advice. I have an emissions (engine)warning light on and trying to diagnose.
    EDIT
    Further testing by scanning each individual ECU came up with the following results.
    Any help would be appreciated.
    These come up as 'SWCAN' scans..
    OP-COM 090821d - PC based diagnostic tool
    Please add your workshop
    name in the settings window
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|BCM (Body Control Module)
    Read Info...
    Identifier: 0x0208
    VIN: W0L0ZCF6841119024
    Part Number:13168783
    Software version number: C12C93 08041404
    Hardware key number:
    System description: TEMIC04
    Variant programming : 0x20202020202020303030363638343839
    Alpha code: EJ
    Manufacturing date: 000400050008
    Code Index and version:
    Total number of fault codes: 3
    B3057 - Security Code Not Programmed
    (00) - Intermittent
    B0967 - Park Pilot Switch Circuit Open or High Voltage
    (05) - Present
    B3916 - No Communication With Alarm Siren
    (0F) - Not present
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|Instrument
    Read Info...
    Identifier: 0x0102
    Part Number:13165955
    Software version number: 8.39 16/03
    Hardware key number: 0000000000
    System description: VDO 0400
    Alpha code: MB
    Manufacturing date: 040510
    Code Index and version: 001 05
    Total number of fault codes: 1
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (7F) - Not present
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|PAS (Park Pilot)
    Read Info...
    Identifier: 0x0101
    Hardware number:50
    System name: PAS
    Part Number:13181070
    Software version number: 0000002D
    Programming Date: 20041904
    System description: BOSCH0400
    Alpha code:
    Code Index and version: 009 01
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    U2107 - Invalid Data from BCM (Body Control Module)
    (71) - Present
    B0952 - Loudspeaker Circuit Open or Low Voltage
    (06) - Present
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|SDM (Airbag)
    Read Info...
    Identifier: 0x0101
    Part Number:13170590
    Software version number: 0C0C3303
    Variant programming : 0x41533035393053303330383238384720
    Alpha code: DW
    U2139 - Invalid Data from CIM (Steering Column Module)
    (00) - Not present
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Infotainment System|TID (Triple Info Display)
    Read Info...
    Identifier: 0x0306
    Hardware number:13190895
    Part Number:13190970
    Software version number: 08.08.17.00
    Alpha code: WZ
    Manufacturing date: 040429
    Code Index and version: 002 02
    U2103 - No Communication with CAN-Bus (Mid Speed)
    (00) - Not present
    These are the one that won't comunicate (time out and no communication errors)
    and come up as'HSCAN' scans
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Engine|Z 22 YH
    No stored codes!
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Chassis|ABS/TC/ESP
    No stored codes!
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|Immobilizer
    No stored codes!
    OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|CIM (Steering Column Module)
    No stored codes!
    As you can see alot of errors relating to CIM, would these be related to my inability to scan both it and engine/abs ecu's?
    Any advice would be appreciated...
    Justin
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Assuming that this is a legally purchased version (Not an illegal Chinese Copy), then I would expect Ilexa to give you all the assistance you need.
    However, it sounds to me that you have simply not turned on the ignition, or you don't have the car running.
    Modules will show as Not Present, if they have not been turned on!! via the ignition switch.
    Or, have you fitted any modules, without programming them into your car?...
    If you simply have a CIM non communication fault, then try fuse 10 at the end of the dash.
    Or try the ABS module connector for clean secure connections.
    I have heard of a loose or missing earth tag on the steering collumn, sometimes causing faults to the CIM.
    And finally, the CIM may indeed be goosed.
    Other than this, as said above, contact Ilexa (the official uk distributor) for any questions you may have.
    If this is not an Ilexa copy, then I am not permitted to discuss it further - forum rules.
    (Piracey etc...)
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    As said Ilexa are the ones you should be speaking to if it's a genuine version
    We don't condone the use of pirated versions so if you have bought it for under 100 off eBay then we can't help sorry.
    Irmscher Insignia CDTI 130
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    my mates wouldnt pick up my 05 vec, had the same prob. as he was only using his for his vec b. he updated the firmware & it picked it up straight away.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    try connecting the USB lead, opening up the software, then connecting to the OBD port, make suer you push on the Op-com well too.
    if not upgrade the software to the latest,
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Thread now closed
opcom no communication with ecm
opcom not communicating ecu
opcom no communication with ecu
opcom wont connect to ecu
opcom could not connect ecm
op com there is no communication with the ecm
opcom not connecting to vectra
opcom not connecting to ecu
eroare ecu module opcomno communication with the ecmopcom no communicationwhat does ecm opcomopel no communication ecmopcom suspension control moduleopcom there is no communication with ecmop com interface not connecting to carэраоре оп опthere is no communication with the ecm on my opcomopcom cant conect to ecu engineopcom there is mo communication with the ecmopcom wont communicate with EHUopcom cannot connect to ecm on opel astra gop com china clone cannot connect to can busvectra c hscanop com does not connect to ecu
