Thread: Heater only blows cold
    Default Heater only blows cold
    Got a 2004 1.8 Vectra C and the heater only blows cold.
    Any ideas what fault could be? I suspect thermostat....
    If so, is this an easy fix and any help you can offer (pictures/instruction)
    PRESTON
    does the engine temp gauge read correctly when the engine is hot??? if it does, then its not the thermostat. More likely to be a sticking flap motor on the heater controls. Sometimes they can be freed up by gentle persuasion and some lube. I think theres a how 2 on the subject, but i do know you have to remove the glovebox (easy job) to gain access to the flap motor.
    Shetland
    one thing that worked for me turn the temp switch to full cold and leave for a few secs then turn to full hot quite fast, repeat a few times and hey presto mine has worked perfect since.
    good luck
    Thanks for this gents, tried the truning the heater control a few times and this morning I had hot air blowing. Cheers again.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    This worked a treat for me today many thanks for the steer
  1. Heater blows cold when idling
    By manimal in forum Bodywork & Interior
    Last Post: 16th February 2012, 02:36
  2. Heater blows hot only
    By laingyc in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 10:57
  3. Heater only blows hot
    By GoldenWonder in forum Bodywork & Interior
    Last Post: 17th March 2011, 12:59
  4. Heater blows hot & cold
    Last Post: 22nd November 2010, 23:45
  5. Heater only blows cold
    By b-e-r-t in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2008, 13:30
vectra c heater blowing cold
vectra c heater only blowing cold
car heater blowing cold air vectra c
