Thread: service today, guess what had broken.....
    Regular Member KevinG's Avatar
    South Bucks
    Default service today, guess what had broken.....
    Booked car in for 6th annual service today at stealers, i know, ikmow, but its on the same estate as my work and they are ok (ish)
    so, quoted £206 plus i wanted aircon re-gassed £55 (kwik fit £49 so thought go for it).
    Hour after dropping off i got the call,
    good morning sir, got a few advisories, ok i thought...
    your rear indicator bulb is blown, £1.56, ok i said
    your rear wiper, could do with being changed, no thanks i said
    o and erm your off side front SPRING has broken and we need to change both (agree) and that will be £406.00
    I will call you back, i said
    To be honest, i did not want to drive my car 20 miles home with a broken spring, as someone said at work, you have probably driven it 1k at least so far.
    So, i called back and said yes, do it
    When i picked it up the bill was £100 less than the original total , i was out of there as fast as i could
    Would i have known a spring had gone?, no knocking, stearing problems.
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Had the springs been replaced in your ownership before
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    eventually they unscrew and cut through the tyre
    South Bucks
    Quote Originally Posted by ROCKATANSKY View Post
    no, had the car 2 years
    South Bucks
    Quote Originally Posted by mattv6diesel View Post
    i guess im glad it was found
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes take a while local taxi did it on the M3
    Regular Member elongmoss's Avatar
    Burton-on-Trent
    you prob wouldnt have been able to tell it all depends where it snapped as however much broke off the front corner it would have just sat lower and possibly noticible with more body roll when cornering to the left hard.
    i had a renault 19 with a front snapped spring couldnt tell at all but my old man had one go on his merc and the noise and knocking was unbelivibile!!
    just have a quick check as well that they have replaced both as i have heard of garages only changing the broken one and charging for both!
    hope this helps
    South Bucks
    Quote Originally Posted by elongmoss View Post
    hope this helps
    will do, cheers
  1. guess where I have been today???
    By accveccysriturbo in forum Petrol Engine related
    Last Post: 22nd December 2011, 23:21
  2. guess what came today
    By aledjones_lex in forum Styling
    Last Post: 11th March 2010, 00:34
  3. Guess were I have been today!
    By merikiito in forum The 'Off Topic' room
    Last Post: 24th July 2009, 14:52
  4. Guess where we've been today...
    By spoons in forum General Chat
    Last Post: 3rd February 2008, 00:15
  5. Guess where I was today ? ? ?
    By Ste in forum General Chat
    Last Post: 28th November 2007, 11:58
