Results 1 to 10 of 19
Thread: Quick led question
    Liverpool
    Default Quick led question
    does anyone know if these will be a direct replacement if the ones found behind speedo and GID screen?
    Liverpool
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There all different types mate, 90 degree, 4 pole and 2 pole I believe. I bought all my SMD's from Crazyleds, they do kits so its quite easy. If that fails PM Kman he's the man when it comes to SMD conversion's and will be able to tell you how many off each type to buy and where the best place to get them from is.
    Regular Member elongmoss's Avatar
    Burton-on-Trent
    just replaced the ones in my vectra with these
    http://cgi.ebay.co.uk/20-x-ULTRA-BRI...item5192a16557
    the ones on that link are side mounting so would be 90 deg out i think that shop does white LEDs as well
    hope this helps
    Liverpool
    cheers guys
    Regular Member brigrif's Avatar
    South Shields
    You need 36 plcc4 for the GID screen and 14 of the ones on ebay for the speedo, or you could just use plcc2 and mount them at 90 degrees.
    Liverpool
    i dont get the difference to be honest, 90 degrees? do you mean so they dont shine light straight onto screen?
    i want to do both speedo and gid screen, as they will be bright white
    Vehicle : SRi
    Mileage : 137000
    By 90 it means instead of the light shining straight up it shines parallel to the PCB.
    PLCC-4
    Liverpool
    thanks rushy
    Regular Member connery-sri's Avatar
    Basildon, Essex
    Sorry to hijack your thread.
    But can anyone tell me which SMD's are required in the window switches???
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
