Results 1 to 10 of 24
Thread: Please Help New Fault
    Aug 2009
    herts
    Default Please Help New Fault
    Hi
    11 months, 11k miles back my alternator was replaced as the red warning light had come up on the dash.
    It appeared again today on a drive to work and when in stop start traffic.
    On the clear run home tonight, when I pulled up outside my house, the car was stuck on a fast idle, the engine was wobbling unevenly, at around 1100 revs and would not drop to the standard idle speed below 1k revs.
    The car is going back to the garage regarding the red battery warning light as they guarantee their work for 12 months. BUT why is the idle now fast and stressed and uneven in the idle at 1100 revs? Please please give some ideas.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Thats a sign of the battery voltage dropping below 12volts, the vehicle keeps the rpm up to try and regain a 12v+ charge, I take it it wasnt a genuine alternator used... and its a 1.9????
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Aug 2009
    herts
    Having read the posts about alternator recalls and that Vx did improve the alternators on the Vectra at some point, when the battery warning light came on again I am concerned a substandard alternator was put on the car.
    The AA came out and the whole battery charge left the battery. As said, with the over idling to keep it above 12v, the alternator has failed and is not charging the battery.
    Was an AA approved garage national chain used to fit the alternator through the AA Breakdown Repair cover scheme where I paid the first £25 back in October 2009 and 10k miles ago.
    It is under 12 mths warranty and should be sorted for me tomorrow.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    good luck
    Aug 2009
    herts
    Wow. So the alternator has lasted 9 months and 10k miles only!
    Aug 2009
    herts
    hmmm. update. after me chasing the garage, the cautious glum response on the phone was that it is not an alternator problem, it is a wiring problem. anyone ever heard of this?
    Full Member Big Sig's Avatar
    What sort of wiring problem? bad earth????
    Aug 2009
    herts
    playing coy, but mentioning maybe needing an auto electrician, and poss not being a job they can do. its an 80k mileage cared for car with fs history!
    Regular Member scottyd's Avatar
    paisley
    it will be the alternator, go to a kwik fit type garage theycan testthe alt for youget it confirmed then go backto garage
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
