Thread: Vectra C door problem
    Runcorn
    Default Vectra C door problem
    Door shows as open on the dashboard when clearly shut. Makes a noise telling you that it is open every time you start off as well. Is there any way of stopping this....Cheers..Colin
    May 2008
    Tyneside
    Sounds like a problem with the door switch or wiring. Check the operation of the switch and connections are good. HTH
    Runcorn
    Hi Tridley. Where is the switch in the door. Know that the older cars had a button that you could press in but how does this one work.
    May 2008
    Tyneside
    Just been to look. Looks like the switch is part of the door mechanism, bit more involved. Need to get the door lock off to investigate. Nothings straightforward these days.
    Quote Originally Posted by tridley View Post
    Looks like the switch is part of the door mechanism.
    Correct, it's part of the door stay that stops the door from opening too wide.
    [Ex]Admin Duncan's Avatar
    First thing to try is adjusting the slam plate - the bit on the door pillar that the door lock latches onto. You'll see it has little markings on the edge, just move it around slightly until you get it closing securely without the light being on.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    nope its in the doorlock mecanisme.
    (theres a how2 how to remove the doorlock, was made because of that error.. but helps for a while if you "punch the rubber in the back of where the pin from b pillar is.. that locks in to the door)
    Quote Originally Posted by kenp View Post
    I stand corrected. Sorry for any misinformation.
  1. vectra c o/s rear door /window problem
    By gsisi in forum Bodywork & Interior
    Last Post: 23rd June 2010, 23:00
  2. Door controls problem
    By damoore1983 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2009, 10:41
  3. tailgate problem, 5 door `02 sxi
    By bloodworm in forum Bodywork & Interior
    Last Post: 21st September 2008, 19:39
  4. door handle problem
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2008, 18:09
