Get a reminder on the dash that the car requires a service. I have just done the job myself. Is there anyway of stopping this from happening.Cheers.....Colin
Hi Colin,with ignition off hold trip reset in turn on ignition holding for a further 12secs approx the service light should change,switch off ignition,switch ignition back on and it should be away,hope this helps.
Hi bigbrox. When yer say trip reset, do you mean for the mileage. Cheers and thanks, will try after....Colin
the button next to the cruise control mate on end of stalk operates the display
Ok Great stuff. Will have a go after and thanks again mate....Colin
Just had a go but hard to tell if it has done anything as the service light only appears now and again. It aint on all the time. When it appears though, it either stays on or goes on and off every few seconds......
How to reset the service "INSP" light on the Vectra....
- With the ignition switched off, press and hold in the odometer button;
- Whilst holding in the odometer button, press and hold the brake pedal;
- Now, continuing to hold the button and the pedal, switch on the ignition;
- Hold down the button and pedal until the "INSP" light stops flashing and turns to 3 dashes "---"; and
- Switch off the ignition.
Thanks again for your responses. Will av a go later when get home from work..Cheers...Colin
sorry colin reset button is on end of wiper stalk not where cruise control is thats the indicator stalk doh
when I pressed my reset, it actually said 21000, it took several attempts to get rid - it kept coming back.
