Thread: Bonnet won't open!
    Regular Member mohojo's Avatar
    Canberra, Australia
    confused Bonnet won't open!
    I recently had my timing belt changed on my 3.2 V6. The day after the job was done I looked under the bonnet and then closed it again. However, since then I can't open the bonnet. The lever under the dash seems to be stuck in the open position. Is this problem related to the timing belt change, or is it pure coincidence?
    People's thoughts on this would be appreciated. Thanks!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Should,nt think it is directly related m8, more a case of how your mechanics went about changing your timing belt.
    Some mechanics will dismantle the front end of the car to make there job easier .
    and what has probably happened in this case is the bonnet release retainers were not done up correctly and the cable has slipped .
    Not sure on the setup on an aussie spec 3.2 but can you reach the top bar with your fingers through the grill.
    if you can, try to get a long flat blade screwdriver onto the return spring and force it outwards with a hard push or strike end of screwdrivewr with a hammer to release the spring.
    stevenage
    Just a thought i had this problem on my 3.2 with the bonnet catch been limp! i just pushed the bonnet down hard went back to the lever he presto it worked WORTH A TRY
    Canberra, Australia
    Thumbs up
    Thanks Bobssignum and John Wake. I ended up taking my car back to the guys that changed the timing belt and they fixed the problem for no charge. They said that "the cable had come out of its holder and that they put it back into position and adjusted the cable".
    Anyway, it's all good now!
  1. Bonnet won’t open!!
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2013, 17:18
  2. cant open the bonnet
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2010, 19:26
  3. bonnet open at 50
    By willoftoon in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2009, 18:50
  4. cannot open bonnet
    By tjsingh in forum Bodywork & Interior
    Last Post: 11th December 2007, 19:13
  5. cant get my bonnet open
    By cow monkey in forum Bodywork & Interior
    Last Post: 8th October 2007, 19:11
vauxhall bonnet wont open
i cant open my vectra bonnet
bonnet wont open zafira b
