Thread: diffuser/ exhaust help.......
    Regular Member mccluskey119's Avatar
    gourock
    confused diffuser/ exhaust help.......
    Hi all I need some advice
    I finally put my vxr diffuser on today and took car to motor care to get my new exhaust put on, when I picked the car up the guy had removed it as the exhaust rubbed against it,
    I was wondering if you can get larger rubber mounts to allow exhaust to clear the diffuser coz i really want it on my car lol
    Plz help
    Full Member spennny's Avatar
    Blantyre
    Wouldnt have thought so mate, i had the VXR exhaust and diffuser fitted , and used the same rubber mounts that were there, sounds as if he hasnt lined it up correctly, was it rubbing alot ??
    gourock
    Not exactly rubbing ? He said he couldn't get exhaust to go on with the diffuser there. A dud buy longer rubber mounts once on al c if this helps fingers crossed lol
    Blantyre
    Doesnt sound right at all mate, is the exhause on, have you tried to fit the diffuser??
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The VXR exhaust sits differently to the stock SRi exhaust, as in the tips are slightly closer together. I have twin stock pipes coming through the VXR diffuser, they only just touch is on the outside edge's but dont cause any problems.
    lincoln
    get him to heat the hanger from the rear box using oxy acetaline mate, he should be then able the stretch the hanger and move the box where it needs to be positioned...thats what i do anyway, never had any problems doing this, even with stainless.
  1. For Sale: exhaust diffuser for twin pipes - sri
    By hairy31 in forum Parts for sale
    Last Post: 10th March 2012, 13:45
