Results 1 to 10 of 13
Thread: got some errors but how to FIX ?
    Regular Member llcoolr's Avatar
    Aug 2009
    ALGERIA
    confused got some errors but how to FIX ?
    B0970 - Hazard Warning Switch Telltale Malfunction
    P0704 - Incorrect Clutch Switch Signal
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (0F) - Not present
    B0283 - Rear Window Heater Low Voltage or Circuit Open
    (06) - Present
    B3596 - Invalid Trouble Code Please Ignore!
    (00) - Present
    (00) - Present
    B2966 - Driver Doorknob Circuit Open or High Voltage
    (05) - Present
    B1240 - CD Mechanism Malfunction
    (00) - Not present
    after made a search found that some errors could be ignored but there is a pre heatting problem and it takes a long time to start.... :d
    car is vectra c year 2007 2.0dti
    Regular Member DarylAAS's Avatar
    South Shields
    WOW thats some problems... Have you not taken it to the dealers as theres problems all over the car....
    Aug 2009
    ALGERIA
    Cool
    all problems fixed but miss this one
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Fuse?
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    is the heater working ????????/ as ken said either fuse or maybe a cut in the eliment.
    Aug 2009
    ALGERIA
    40a fuse is good....................
    what else
    Aug 2009
    ALGERIA
    Quote Originally Posted by soulman View Post
    bro can u explain more for me !!!!!!!!!!!!!!!!!
    the winter is coming if u see............
    Regular Member Marky's Avatar
    Jun 2006
    North West
    How did you fix this one??
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by llcoolr View Post
    what else
    Maybe a bit late but the spade connector on the side of my rear heated window fell open as was loose, I cut and crimped a new female end on and jobs a goodun! Check yours under the plastic panel either side the window.
    Also - to fix "U2139 - CAN-Bus No Communication with CIM (Steering Column Module)" did you replace the CIM? My clocks are dropping out randomly.
    Si
    loughborough
    Quote Originally Posted by si_hoss View Post
    Si
    I have this problem,
    All the dash goes out speedo / rev counter, everything stops working, but it still drives, and i have a big list of faults after this including:
    No communication with cim
    No communication with bcm
    No communication with rec
    Is this a CIM problem?
  1. ECU code errors
    By clowe7447 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 16:34
  2. Canbus errors? What am i doing wrong?
    By thunderpantz in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 17:22
  3. unkown errors help please!!
    By steve66 in forum Engine & Drivetrain
    Last Post: 30th September 2010, 21:30
  4. Errors on engine management
    By Nojustice in forum Engine & Drivetrain
    Last Post: 12th September 2010, 19:49
  5. Recent database errors etc.
    By Admin in forum Site updates etc.
    Last Post: 5th February 2010, 16:10
