Results 1 to 10 of 13
Thread: that cant be already.....
    Regular Member bunsen1's Avatar
    suffolk
    Default that cant be already.....
    hi guys, cleaned my boost censor around 4weeks ago, just took it off to have a look at it and it is absoulutely covered with none of the yellow showing already, now as it attaches to the manifold which i had done last weeks would the old manifold with the swirl bar off make this collect carp as quick, gonna clean again now but should it get coked this quick? would it be the old shot manifold that done it and a clean now with the new manifold in place keep better for much longer?
    any comments always gratefully received
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    its the mix of egr gasses and your oil breather system spraying oil into the inlet manifold this causes the crud build up i had same issue as you had inlet manifold replaced and now i have blanked my egr with a plate with a 5mm hole in to keep the light off
    and also vented my oil breather system to atmosphere to stop the oil mist and spray going into the manifold i will have a serch on here nd throw up the links for you to read
    kings lynn, norfolk
    http://www.vectra-c.com/forum/showth...light=breather
    breather post i know its a lng read but worth it i hve changed the orginal design in the 1st page but if you read it all then you will find out how and why
    http://www.vectra-c.com/forum/showth...t=egr+blanking
    this is the gaskets you can use or make your own from a coke can or sheet aluminium like mine and drill a 6mm hole in
    hope this helps and let meknow what your plans are thanks
    suffolk
    mate i have semi blanked th oval side with the fiat gasket, and today out of cadburs hero tim made ( well kind of) a plate to sit square gasket side, as i didnt want to fully blank i have drilled 7 6mm holes in the middle and i still have the light on the bottom right of the dash? exhaust light isnt it. will it go its self or should it go straight off as i thought that would be plenty to keep it off
    kings lynn, norfolk
    should be plenty holes you might need to reset it
    have you read the oil breather post?? thats the main cause for the crud
    and my blanking plare has only one 6mm hole in and no light on
    suffolk
    had already read the breather post but thanks, had the light on before and it went off after a while but i cant remember if it was when i put the first semi blanking plate on or when i did the swirl valve mod and it didnt work, stopped the motor on the 3rd valve moving which brought limp home mode on, so you dont think it will clear on its own? or should i put more holes in it to see? if doesnt work i will just take out i think
    kings lynn, norfolk
    you have more than enough holes mate it could be a diffrnt fault than the egr your best off getting the codes read and reset the blanking plat should work with just one hole in as it only neeeds a trickle flow to keep the light off
    even with the egr blanked your manifold will be clogged up in a few 1000 miles due to the oil and heat from breather
    since my blanking and oil breather my manifold is squeaky clean after 6000miles no dposits at all
    suffolk
    had no light on in the bottom right hand side of the dash before doing it, think it may just not like it, they charge for resetting dont they, after flywheel manifold 3rd injector and buyiny the bloomng thing in the last 6 weeks i aint got money to spare
    kings lynn, norfolk
    have a look on the forum if some one lives close with op com i have it so i would of done it for free but live a bit too far away lol
    try d/c battery for a good few hours or over night see if that works
    suffolk
    what with gasket still on?
