Thread: dmf / solid conversion help please
    derby
    Smile dmf / solid conversion help please
    hi all, have been a browser on here for a while now and am after some advice please,
    i have a vectra c 2.2dti 2003
    i have brought a 2.2dti vectra b engine with solid flywheel attached, as i blew my engine up and the dmf is knackered
    i have measured up and the dmf is 20mm thicker than solid one so i would need a 20mm spacer behind the slave cylinder
    but it i do this it looks like only halve of the splines in the clutch will make contact with the gearbox splines,
    have you any idea if you think this would work with halve the splines in clutch making contact? also do you think my gearbox is different to a vectra b one?
    any help much apreciated as engine is ready to go back in and im stuck also if i can get it to work i will post a how-to up
    many thanks for your time
    lew
    Regular Member DaveW555's Avatar
    Cannock
    As far as I'm aware there isn't any conversion kits available so you'll more than likely have to replace the dual mass.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just had a poke about mate and the Vec B and Vec C 2.2dti both use the F35 WR and both with the same final drive, the only thing that might differ are the mounting points and if there hydraulic or cable operated, but a quick visual should tell you that.
    Steve
    Regular Member Jezzy's Avatar
    S.E
    What about the Vec-B engine not having any CANbus capability - won't that fubber things up?
    Vehicle : SRi
    Mileage : 137000
    I think its just a case of swapping over all the Vec C parts onto the bare B engine inc fuel pump.
  1. solid flywheel
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2012, 18:31
  2. Dual Mass To Solid Flywheel Conversion Kits
    By sloper in forum Diesel Engine related
    Last Post: 4th March 2012, 14:41
  3. solid conversion flywheel
    By abz123 in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 21:43
  4. DMF or SOLID?.
    By felixx in forum Engine & Drivetrain
    Last Post: 15th February 2011, 21:33
  5. Solid paint
    By thestaffy in forum Detailing and Car Care Discussion
    Last Post: 18th April 2007, 01:42
vectra dti solid flywheel conversion
