Thread: Do my rears pads have a spring?
    Regular Member LEE_2007_SRI's Avatar
    UK
    Question Do my rears pads have a spring?
    Looking to replace my pads all around on my 2007 1.8 Vectra SRI and looking at these:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
    I asked the seller about fitment and got the response:
    Hi, according to our system the pads will fit the vectra c 1.8 sri model as long as it has rear pads type fitted with no spring, as pictured, if your model has rear pads with springs then the package is diffrent , but same price, and you can purchase via the listing and just add in the paypal notes you require rear pads type with the rear spring so we can send the correct sets out.
    thanks.
    Will my pads have a spring or no spring? I don't want to take them without having the replacements available.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    what springs are we talking about here? the one at the top edge of the pad, the one on the back of the pad or the ant-rattle spring?
    obviously the anti-rattle one is defo needed, but the one on the top of the pad really depends on who manufactures them, same with the one on the back. the one on the back was missing from the genuine VX pads i got when i did my rear brakes last year, they had the ones on the top edge tho. have had no problems with them since fitting.
    Regular Member Jezzy's Avatar
    S.E
    The fixings on the pad changed during the life of the Vec, although both types can be used on any car. The old type had a hinged wire that was supposed to fit into a groove on the outside of the piston, the newer type (which is what you should get) had a fixed clip that goes into the piston.
    May 2008
    Tyneside
    The spring clip is on inner pad which sits next to the piston but the spring grips the carrier, not the piston. Here's the difference in pads. http://www.vectra-c.com/forum/showthread.php?t=67661
    UK
    so I need rear pads with the spring correct? As these are the newer type
    May 2008
    Tyneside
    Quote Originally Posted by LEE_2007_SRI View Post
    Correct, but as stated both old and new types will fit, but personally I would fit new type. Only two of the four pads supplied have springs fitted, as stated these are the inner pads which sit next to the pistons.
    UK
    Cheers all
  1. Your rears
    By Sri-chris in forum Styling
    Last Post: 30th November 2011, 18:43
  2. Quicky! Rear pads, is it the inner or outer with spring?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 11:23
  3. Rear Spring Pads...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2010, 14:56
  4. Spring Clamps - Are they needed for the rears...
    Last Post: 19th January 2010, 17:43
  5. Help - New Discs / Pads and a coil spring!
    By darrynwarner in forum Handling & Braking
    Last Post: 10th July 2009, 22:33
