Results 1 to 10 of 11
Thread: Z20net dump valve Help!!!!
    wrexham
    Default Z20net dump valve Help!!!!
    Z20net dump valve? Anyone? 2.0t signum please any part numbers or anybody got one ?
    Last edited by bigmac; 5th July 2010 at 17:01. Reason: Maybe saying what you need help with will actually help
    Regular Member Jezzy's Avatar
    S.E
    Just for the sound, I presume? The engine already has a turbo bypass valve, that does the same job as a dump valve but in a much more elegant way (instead of dumping boost it uses it to keep the turbo spinning whilst still bypassing the cylinders).
    WGAF#5
    there are several members who do have them fitted - but if you get it wrong then you will induce engine faults - have a search and you will find there is a how2 .. the other option is a cold air intake which will provide less issues (providing its not a K&N) and you will hear the recirculating dump valve already fitted working as well as the turbo spooling
    S.E
    The other option is to purse your lips and exhale rapidly through them.
    11 Post(s)
    If you want to draw attention to yourself, why not just put a red/white flag on your car?
    Regular Member signumturbo04's Avatar
    SCOTLAND
    Cambridgeshire
    i have one fitted matey , manufactured by forge motorsport. about 140quid give or take, various ebay sellers and websites, just google "vectra c dump valve"
    forge also sell the kits direct from their website but are usually moe pricey
    wrexham
    i wouldnt put a red and white flag on my car as i am not english! cheers do you know what boost the turbo runs and and if the boost can be turned up without changing the internals of the engine? e.g. conrods pistons ect? and what is the sound of stock exhaust on them ? ( as you might gather havent purchased one yet) and what is the lag like? what is the rev range of thy turbo? so0 many questions so little answers! o and thanks for advice already.
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    The Z20NET is like 'soft' turbo (as used in the Saab 93) and not a 'kick you in the head' turbo engine like the LET. The exhaust burbles away at idle but that's about it. Turbo kicks in from around 2.5k rpm. Really don't think you can up the boost mechanically/manually as it's all ecu controlled. There are a few tuners to remap/chip it to get around 210 bhp, but don't expect a massive amount of support for the engine. Tuners only seem interested in the VXR vauxhall stuff
    Regular Member Marcosuk's Avatar
    Fife
    Mine holds boost around 8-9 psi standard form.. Turbo spools up about 1.5k revs
  1. Z20NET and a dump-valve
    By hog in forum Engine & Drivetrain
    Last Post: 16th June 2012, 17:34
  2. Dump valve fitting z20net
    By tomo41 in forum Engine & Drivetrain
    Last Post: 14th July 2011, 13:14
  3. who as a dump valve fitted to there veccie turbo z20net
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2011, 21:35
  4. dump valve z20net remapped engine
    By tomo41 in forum Petrol Engine related
    Last Post: 6th June 2011, 22:26
  5. Dump valve fitting help on z20net
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 21:47
z20net dump valve kit
dump valve hose kit z20net
forgen dumppi z20net
z20net recirculation valve
z20net recirc valve
