Results 1 to 10 of 16
Thread: how do i know if i have factory xenons?
    Regular Member vectra_'s Avatar
    australia
    Default how do i know if i have factory xenons?
    i know it sounds stupid but im gona ask still
    also hid and xenon are the same things yeh??
    another question is that, ive got a vectra CDXI so i heard that all cdxı's come with projector headlights?
    Cambridgeshire
    If you open your bonnet and have a look at at back of your headlights. If there are wires/cable sticking out of the cover for the bulbs then it will be aftermarket like mine. If not then they could be OEM HID's or just standard halogen.
    Next test is by turning the lights on in the dark. If they start out dim (low light) and gradually (over a few seconds) get brighter, then you have HID's
    PRESTON
    the dealers can tell from decoding your chassis number what the car left the factory with, just give em a call.
    Factory xenons will have headlight washers, and the beam height knob by the headlight switch will be missing.
    australia
    hıımm...does the cdxi have projectors then?so i dont need to get a xenon kit if i have the projectors..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    all Vectra C have projector lights..
    Look at your light switch.. if you have a level ajuster for the light, you dont have xenon.. (atleast not OEM)
    australia
    so i dont have to buy a xenon kit, because ive got projectors? is that right??
    and whats the difference between hids and xenon ? :s
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    no different hid's are xenons Most ppl call factory fit the xenons and aftermarket HID's (High Intensity Discharge i think) and the gas inside the bulb is actually a xenon gas as far as i know
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Ashington, Northumberland
    Quote Originally Posted by plasma View Post
    Spot on there Mr F.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Quote Originally Posted by vectra_ View Post
    As said, all Vec-C's have projector main beams, the one with the lens that looks like, er, you know, a projector. They can be either Xenon or Halogen types. Your sidelights/high beams are a standard reflector type.
  1. Factory fit xenons
    By tomh in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2012, 21:45
  2. Factory fit xenons adjustment.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 21:26
  3. Xenons
    By ukmayhem in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2009, 21:46
  4. Replies: 17
    Last Post: 25th February 2008, 15:20
  5. Bulb failure warning for factory Xenons?
    By stevedee3 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2006, 12:53
