Thread: Oz Vec
    Ian Gray
    Guest
    Default Oz Vec
    Have any of you changed the rear axle stub bearings? My bearings are making a lot on noise and in Australia one set could cost Aus $450.00 a side for a complete stub set.
    Can I just replace the bearing inside the set?
    Does anyone have photos or advice.
    Ian
    May 2008
    Tyneside
    The rear hub bearings have to be replaced as a complete unit. Plenty on ebay, although postage to Ozzy might be expensive, but not $450. http://cgi.ebay.co.uk/Vauxhall-Rear-...item35a870367e
    Ian Gray
    Guest
    Man are you sure they can't be pulled apart and have the bearings replaced.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Ian Gray View Post
    Do you have some deep desire to do it the hard way? Lol. Bolt-on/bolt-off ones are much easier.
    Ian Gray
    Guest
    Na Mate, I just don't have the ready to throw at it. Plus I came from a time when you did all work on cars as much as you can. I don't mind the work, I like to do as much as I could.
    Ian
