Results 1 to 10 of 14
Thread: 12v Impact wrench, Any body used one
    Regular Member eaglepva's Avatar
    Up North
    Default 12v Impact wrench, Any body used one
    Was thinking about getting one of these and leaving it in the boot of the signum. But do they have enough grunt to do the job.
    Fleabay item number: 280512192736
    Mileage : 000
    If it is just for undoing the wheel nuts. I bought one simalar. It worked ok. But I prefere to use a long breaker bar, not so heavy or bulky to carry around either.
    Cambridgeshire
    yes......and no. usually they do but if some idiot who last refited the wheel nuts didnt tourque them and just let the airgun click over for ages then chances are they will be too tight.
    personally i wouldnt want to risk getting them all off apart from one stubborn one and then be stuck not getting the wheel off!
    Oct 2007
    Shropshire
    I work selling tools and take it from me, - don't bother! They are not that good and certainly not worth carrying around!
    N
    I keep a breaker bar in the boot cubby hole (think a medical kit should be in there!).
    Admin plasma's Avatar
    On the Forum
    315 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by mucklestone View Post
    Would disagree with that!... I had a sealey one at 285ft/lb's which wasnt much cop really... Changed it out for the 400ft/lb and its amazing... Makes changing springs, dropping the legs etc etc soo much easier.. Just ask soulman or anyone else whos had use of one... The smaller one are as you say not worth a **** . But the bigger heavy duty ones are invaluable..! (to me at least)
    Just seen the one you linked in ebay, all that will do is tickle the nut lol...
    Have a look at this bad boy...
    http://www.eurocarparts.com/ecp/p/To...P3004&0&t5_349
    400ft/lb's = 542nm's!!! And if you imagine your gearbox is limited to 400nm's its shows you the power it has!
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member Rab's Avatar
    Irvine
    we have a few of these in work. dewalt 18v i cant fault them tbh. more than upto any job on a car.
    Regular Member DaveW555's Avatar
    Cannock
    I've got the snap on 18v cordless impact wrench and its the mutts nuts, them fag lighter plug in ones wouldn't undo 110Nm which is what your wheel nuts should be torqued to.
    Ashington, Northumberland
    THIS is the one I have at work. Believe me it's good. The moral of the story is, yes they are good as long as you're prepared to spend £300 plus. Then you got to ask yourself, 'how often will I use it'
    I use mine daily so I can justify the cost.
    Regular Member hagga's Avatar
    kingswinford
    I wouldnt bother for your wheel nuts...but useful for other stuff..I had a cheap £30 one that was great for suspension changes.. no more messing about with nuts on the top of shocks
  1. Battery Impact Gun
    Last Post: 7th February 2013, 10:11
  2. Impact driver
    By RBH in forum General Chat
    Last Post: 21st May 2012, 19:56
  3. Impact on MPG
    By Quirrel in forum Engine & Drivetrain
    Last Post: 30th December 2011, 21:47
  4. Deep Impact.....
    By spoons in forum The 'Off Topic' room
    Last Post: 25th June 2008, 16:08
  5. £ 9.99 Impact wrench
    By SCOTTEX in forum General Chat
    Last Post: 21st February 2006, 12:02
