Thread: Handbreak cable reset?
    Gävle, Sweden
    Default Handbreak cable reset?
    My handbreak cable is way to tight now, can it be reset somehow? There seems to be an adjuster of some kind under the console (where the lever mechanism is located). Can this be reset here?
    May 2008
    Tyneside
    You can adjust the handbrake cable at the lever, just lift the rubber gaitor. The cable usually need adjusting when it stretches i.e. too loose, not too tight. Have you checked the rear pads are not worn and also that the cable is not seized. HTH
    Gävle, Sweden
    Have just replaced the rear pads, and noticed that the cable was too loose (i.e. parking brake not working). I removed the console inside the car, and pulled the lever a few times. Now the cable seems to be way too tight?! So I assumed there was some automatic adjuster at the lever.
    The lever is connected to a pin with a spring, can this pin be adjusted in some way?
    If I would like to replace the cable. so do I need to disassemble the exhaust system??
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    how do u adjust the handbrake is there a how 2?
    Gävle, Sweden
    Anybody please? I need some advice in how to release the automatic adjuster located near the handbrake lever.
    Regular Member DaveW555's Avatar
    Cannock
    They are self adjusting, put your foot on the brake and pull the handbrake a few times you should feel it through the brake pedal, give the handbrake 5-10 pulls and release the foot brake and se how it is then.
    Sep 2009
    swansea
    Trim : Club
    Quote Originally Posted by DaveW555 View Post
    do you do it with the engine running or without mate?
  1. handbreak question.....
    By vectra gsi 3.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 02:13
  2. Adjusting Handbreak
    By Alank in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 23:26
  3. Need to replace handbreak cables
    By stryker99 in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 15:03
  4. XBox 360 VGA cable and Advanced SCART cable FS
    By RSV_Ecosse in forum General items for sale
    Last Post: 2nd February 2007, 00:01
vectra c handbrake reset
resetting a vectra c handbrakevectra c hanbrake resetreseting handbrake cable in vectra cvectra c handbreak self adjust resethow to reset handbrake on vectra cresetting self adjusting handbrake
