Thread: heater problems!!
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Thumbs up heater problems!!
    hi,can anyone help??my blwer swich numbered 1 to 4 speeds only works on full blast(no 4)!!its really annoying as i cant even have a conversation with the passenger,does anyone know how i can cure this problem?thank you peeps!!!daz
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    have a search on here for that.. Your resistor pack has blown due to water ingress via the pollen filter housing due to the drain off on the scuttle panel by the wipers being blocked!
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    thank you!cheers
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    79p fix from maplins. Search for thermal fuse
    Nov 2009
    Northern Ireland
    does anyone know which part number I would need for an '03 2.2 dti?
    http://www.maplin.co.uk/module.aspx?moduleno=470
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    its the last one - RA23A 240c - as long as you dont have climate control
    Nov 2009
    Northern Ireland
    thanks ben
  1. Heater fan problems
    By woodley Vectraman in forum Bodywork & Interior
    Last Post: 14th July 2012, 20:43
  2. Heater Problems, And then some.
    By Deathtopia in forum Vectra C / Signum Troubleshooting
    Last Post: 9th February 2011, 09:58
  3. heater problems
    By pete w in forum Bodywork & Interior
    Last Post: 12th December 2010, 21:28
  4. heater problems
    By blackcountryroy in forum Bodywork & Interior
    Last Post: 16th January 2010, 19:38
  5. Heater Problems ???
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2005, 01:10
