Results 1 to 10 of 14
Thread: front and rear bumper removal Vec C
    in a house
    Default front and rear bumper removal Vec C
    can someone point me in the right direction please,irmy grill and vxr diffuser waiting to go on
    cheers
    Regular Member mikeeaston's Avatar
    widnes
    the front bumper, 4 screws at the top, 2 in each wheel arch and 5 underneath then just pull the side of the bumper away from the wing and disconnect air temp and fogs if fitted
    rear bumper , remove rear light clusters, 2 screws in each wheel arch and 2 near the number plate lights again pull the bumper away from the arch and i used a thin knife in bewteen the 2 plastic bits ( u will see what i mean lol ) then possible 2 little plastic clips underneath the bumper if they are attached ( mine wern't )
    hope this helps
    widnes
    when removing the diffuser i used about 6 thin knives on the clips to save breaking it again it probably sounds arkward but one you start removing screws on ur bumper it is realy easy
    in a house
    thanks mike,
    "i used a thin knife in bewteen the 2 plastic bits"
    go on, tell me more .lol.
    on the front bumper when you mention pulling the bumper away, is that because there on locating lugs? from past experience on other bumpers i had to slide them into runners. just dont want to go pulling something that could easily snap
    widnes
    sorry m8 it is hard to explain really they are just on little lugs, the bumper just pulls away from the wing and then just click back in when refitting.
    to be honest it is probably the easiest job to do on the car and once u have located all the screws it is just common knowledge really and when u have removed the bumpers u will see exactly how to remove the diffuser aswell
    in a house
    cheers mike, just got to fathom out the irmy grill, it came with a backing plate and again i suppose once the bumpers off i will see the way to do it
    widnes
    yeah m8 u wil,l i had never done it before the other day and it took me about 1 hour to fit a vxr diffuser and swap chrome lights for the sri black lights
    Sep 2009
    belfast
    In having difficulty removing thhe clips at the subframe as it they wont budge any ideas on how to do it. Its freezing out and i need to get bumper changed tonight
    Full Member spennny's Avatar
    Blantyre
    What clips on what subframe ?
    Sep 2009
    belfast
    The black clips at back of bumper there is 4 of them kinda make a splash shield
  1. replaced Rad without removal of front bumper
    By dcm23251981 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2012, 14:25
  2. Front bumper removal
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 15:36
  3. front bumper removal
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 18:04
  4. Front bumper removal
    By Steven T Davies-Moss in forum Styling
    Last Post: 1st January 2009, 20:49
  5. Front Bumper Removal Help
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2005, 14:52
vectra c rear bumper removal
