Thread: connection to cig lighter
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default connection to cig lighter
    need a live feed to my sony headunit what type off connectors do i need, and what type of wire do i need, is it just the one wire to connect, havent a clue when it comes to electrics, was told to wire it from the ciggy socket
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    For ignition live, you need to tap the correct wire from your radio to the black wire of the cigar lighter socket.
    From memory,
    Most aftermarket radios use
    Yellow for battery live (red on the Vauxhall loom) - used for memory
    Ignition live is red, (black on the Vauxhall loom).
    I would strip about 10mm of insulation from the side of the black wire of the cigar lighter, then solder your radio's red to this, and then insulate either with heat shrink sleeving or decent PVC insulation tape.
    Do NOT use the black wire on pin 11 of the big quadlock connector on the back of the radio, as this is not ignition live...it is the telemute wire!!
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    would i need a fuse on the live feed or would the fuse on the back of the headunit do the job, also do i have to ground the live feed.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you are being pedantic, then you could indeed put a fuse in-line, however this should not really be necessary as both the cig lighter / charge socket and the head-unit will have their own fuses.
    You only need the live from the cig lighter (black)
    The earth is already in the head-unit wiring loom (brown on Vauxhalls) pin 12 on quadlock.
    You don't ever ground a live feed!!
    That will blow your fuse / melt the wire or simply set fire to the wiring.
    Unless of course you have a 1959 morris minor with dynamo and +ve ground rail
    Nov 2009
    Norfolk
    Cant you just pop to Halfords and buy an ISO connector for the stereo, then it will plug straight in?
    Especially as you said you don't know too much about electrics!
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    have a iso connector but you need a live feed for full canbus cars
  1. live connection cig lighter
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 12:43
  2. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  3. Anyone know which connection??????????
    By VECTRA1974* in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 01:38
  4. USB Connection?
    By romit2001 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2008, 20:03
  5. Is this the VDA connection
    By caravaner-tony in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 22:14
