Thread: Vectra C 2.2DTR Electric problem
    Jul 2010
    Haarlem
    Default Vectra C 2.2DTR Electric problem
    Hello there,
    First of all i'd like to introduce myself. i am Dennis , 23 years old , from Haarlem (in Holland, next to amsterdam)
    I'm doing my best to write proper ennglish, but you might find some spelling errors
    I couldnt find any good dutch forums for vectra-c cars so that's why i'm here.
    I'm having problem's with my Vectra-C 2.2 DTR , 2003. In the past the spanning-with-car logo came up now and then , but after restarting the car the problem was gone, so i dindt think there was anything wrong. After that the warning sign showing a lightbulb came up now and then , but the lights were working fine. (all of them).. after a whiile this warning sign also diappeared..
    since yesterday i'm having all this signs including a sign of power steering after starting my car.. i started driving.. withoutt power stearing , after a few minutes power steering was back on , but car went into limp mode.. Also dashboard lights stop working now and then... and final.. the battery sign is always on while driving..
    The strange thing is.. Sometimes EVERYHING works just fine and the car doenst seem to have any problems.. it's really confusing..
    Does anyone have any idea what this could be? (i don't have any equipment myself to test things myself, so i cant read-out error codes etc.)
    Thanks in advance !
    WGAF#5
    hi and welcome to the forum = the first thing you can try to do is see if you can read the fault codes with the brake pedal
    if you post up the faults recorded they may help point you in the right direction
    make sure ignition is off press the brake and accelerator pedal keep them pressed turn the ignition on and count the flash (of the engine management light) ie 10 flashes = 0 so it just flashed 10 times 0 then it flashes six times 6 then flashes four times 4 then it flashes 5 times your code is 0645 then put a p in front so it would be p0645
    Jul 2010
    Haarlem
    thank you ,
    Maybe stupid question .. but do i need to fully press the accelerator pedal to the bottom ?
    thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Hello Dennis, you say that the battery light is on all of the time while driving, get the Alternator checked out as this would cause problems with the electrics.
    The pedal trick to read the codes may not work on your dti as the trick doesn't seem to work on them
    Jul 2010
    Haarlem
    thank you John,
    is there a way to check this myself ? or is it better to bring it to Opel ?
    (the alternator is like the dynamo .. right ?)
    btw... the battery sign came up a little later (15 mins. approx.) then the rest of the error signs.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah thats right
    With all the faults you've listed probably best to take it to an OPEL dealer to at least get the fault codes read and then go on from that
    Jul 2010
    Haarlem
    Ok will do !
    thanks for the support .. i will write down the solution when it's fixed (hopefully soon)
    Jul 2010
    Haarlem
    Well , The car is fixed Indeed the alternator was broken. They wanted to replace it for a new one .... €1015 euro for all of it , including tech2 readout and placing dynamo. little too much money if you ask me.. so i bought myself a used alternator for €100,- (with 41.000km driven) and they placed it for me! now in total i've paid €350.- for everything.. 1 third of they price they wanted me to pay
    Thanks for your support !
    Greets, Dennis
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Glad you got it fixed mate
  1. vectra diesel electric problem
    By manunut1969 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2013, 17:19
  2. Vectra electric boot problem
    By planetgarb in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2012, 13:04
  3. Electric problem !!!
    By m.service in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2011, 13:42
  4. Electric Window Problem
    By TrevF in forum Bodywork & Interior
    Last Post: 19th October 2008, 15:15
  5. electric window problem
    By jon ixi in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 23:23
