Thread: CD70 and TID display is it possible?
    North Yorks
    Default CD70 and TID display is it possible?
    Thats the question guys.
    Am not really bothered trying to get the MID or CID display but I have a divorced cd70 and would like to replace my CD30 mp3 with it.
    Am negotiating a play with the tech2 at the local stealer and wanted to know if it will work OK without errors.
    Regards
    Dunstable
    Very much doubt it'd work mate, for a start I don't think the display would show any of the radio details etc, and also it may need the original screen fitted for it to work as they're usually paired together. As you're not upgrading the screen you wouldn't benifit anything by fitting it, so I'd stick to your CD30. You won't be able to use the satnav without the screen and you wouldn't be able to change any other settings. Hope that helps.
    Wondering lonely as a cloud
    21 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    As said above, CD70 is only compatible with a Monochrome Graphic Info Display, or with the Colour Info Display. (GID & CID)
    Keep an eye on ebay,
    I bought a GID for mine about two month ago for £16 !!
    CID's are like rocking horse poop, and so are very expensive.
    Going from CD30 MP3 to CD70 Navi, with a Triple Info Display, will show no difference, and you will have gained nothing, as both will provide,
    Radio, CD and MP3's on CD...that's it!!
    North Yorks
    Thanks guys. Have resigned myself to trying to sort out the CD30 for now.
    Ive posted another thread RE: the lack of rear outputs and no Fader.
    Gonna try and get my mate at Vauxhall to reprogram the CD30 with a Vectra code (his words not mine). Which will hopefully bring back the 2 rear channels and the Fader in the menu.
    Any ideas
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Yes he will need a Vectra "Code Index", and then do the variance coding to set the screen up to suit your vehicle.
    North Yorks
    Thanks Robsey. Will let you know how it goes
  1. CD70 display
    By DHobbs in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 13:14
  2. Cd70 and display question
    By RBH in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2011, 11:52
  3. CD70 Display
    By floppus in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2010, 01:46
  4. CD70 decode and display
    By henryf in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2010, 20:36
  5. Change display CD70
    By FLi in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2007, 18:10
