Results 1 to 10 of 15
Thread: 2.2 Direct Big Issue!
    Regular Member Sambor's Avatar
    Elgin
    Default 2.2 Direct Big Issue!
    Sory writting new thread but I'm just P.. off!Pick up my car yesterday after timing chains has been changed.And what?Today metal noise comining from engine.Back to VX and after 2 hours call-"Your water pump for 90% is faulty"!I thought that is joke!Why they didn't advise me that is better to change WP as well?!I'll talk to menager on monday.I'll not pay any pennys for the same job to be done!
    Any sugestions mates?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    water pump isnt near the primary chain and sits in a houseing on the back of the engine it is also run from the balance shaft chain it wouldnt be checked in any way when the oil pump was removed due to the fact you cannont test it in any way ....unless it is leaking or noisey no way of testing ,,, did they fit the new z2.0net tenstioner ?...also the job of replaceing the water pump will not be the same as doing the primary chain it is a different job ..how much they quoted?
    just noticed you have had a balance chain fitted too ...are you shure they fitted a balance chain kit ?......they would have had a good idea if it was faulty with the balance chain removed ....
    Elgin
    They changed also the balance shaft chain!!I have old parts at home!Paid £700!
    Feb 2006
    dudley
    £700 wow ........ did they fit the modded z2.0net tenstioner too ? .....a water pump is only about £60 ....how much they asking to fit the pump,,, ? ..
    Elgin
    I don't know how the new one look like?
    Is this one?
    http://www.vectra-c.com/forum/showth...=103513&page=3
    Would this have been Regency Elgin by any chance...?
    Elgin
    Yes!Regency Elgin.Should they replace water pump without any extra charges?
    Why did You asked Penfold101?
    I've been there a few times when I lived up there mate. Most unhelpful, boring and lazy workers I've come across in a VX garage...
    Elgin
    But I think they should do it with no extra cost?What do You think?
    Feb 2006
    dudley
    i would kick up a stink and pay for the parts only ..! get them to fit it for free if you have had all that work done at that cost .....but im thinking it wont be the water pump but i hope it is for your sake ......
  1. Replies: 3
    Last Post: 21st July 2012, 22:02
  2. Z22SE 2.2 Non-Direct Starting Issue.
    By Lean6 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 23:29
  3. Help please. Starting issue 2.2 Direct SRI
    By fidzer in forum Engine & Drivetrain
    Last Post: 29th June 2012, 10:16
  4. 2.2 Direct full throttle issue
    By Morzy in forum Engine & Drivetrain
    Last Post: 7th May 2010, 18:31
  5. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
