Thread: Af40 auto box drain and fill plug locations
    salisbury
    Default Af40 auto box drain and fill plug locations
    Attached you will see what i think are the drain plug and refill point for the oil on my AF40 box.
    is this correct as i cant see anything else that looks correct or is the hex plug the one that should never be touched!
    Haynes manual lists and shows it as a bolt type which i dont have.
    advice welcome
    cheers
    salisbury
    anyone?
    salisbury
    please!
    Regular Member DaveW555's Avatar
    Cannock
    the drain is below the drivers side driveshaft and slighty towards the front of the car, the filler is by the gear selector from what I can make out from the pics on autodata. hth.
    Regular Member s-owen4's Avatar
    Aug 2010
    Consett
    Did you ever deterrmine if the pic is the correct drain plug? You are correct about the filler but not sure about the drain?
  1. were is the drain plug on a af23 early auto box
    By bert01909 in forum Engine & Drivetrain
    Last Post: 20th September 2011, 15:11
  2. auto gearbox drain plug
    Last Post: 19th September 2011, 18:14
  3. Help : af40 stripped fill bolt
    By maxou2 in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:44
  4. Location of auto drain plug on a 3.2?
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 22:56
  5. F40 Oil Fill Plug..?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2010, 19:11
insignia af40 oil filler
vauxhall af40 auto box drain plug location
