Results 1 to 2 of 2
Thread: Aircon low-side port ..where is it ??
    HULL
    Default Aircon low-side port ..where is it ??
    Hi ,
    Which is the Low side port on a 2008 Vectra , i can see 2 at the front on the car the one on the left which is slightly lower , i think is the coolent for the radiator ?
    .. In the middle left there is one a bit higher that runs along the front on the radiator etc... Is this it ??? ..if so why is it call the low side ??
    ..i can only see these 2
    many thanks
    Regular Member Jezzy's Avatar
    S.E
    If you've found the 2 air con pipes (silver coloured pipes, with black dust caps sticking upwards - take the caps off and you find a pair of scrader valves [just like tyre valves]), then the low side is the fatter pipe.
  1. Aux in port
    By R88KMJ in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2012, 23:03
  2. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  3. Iso Port to Quadlock Port
    By Jez1516 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 01:35
  4. Aux In Port
    By leeds vectra in forum Parts for sale
    Last Post: 1st December 2007, 11:49
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
vauxhall vectra air con connection
ac low side service port vauxhall vectra c
low side port vectra diesel 150bhp
low pressure port vectra cdti
