Results 1 to 10 of 21
Thread: how much gearbox oil do i put in a v6 cdti
    n.ireland
    Default how much gearbox oil do i put in a v6 cdti
    heelo people i was gonna change the gearbox oil in my vectra v6 cdti tommorow and was just wondering how much to put in.
    Regular Member DaveW555's Avatar
    Cannock
    Manual Gearbox - F17=1.6ltrs F23=1.55ltrs F35=1.9ltrs F40=3.2ltrs, Auto Gearbox - 3-3.5ltrs.
    n.ireland
    would the gearbox on the v6 cdti be an f40
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Wasn't there a field remedy for the F40 to drain 0.8L of oil? That would be 2.4L then Better to doublecheck this though...
    When I changed the oil on my old V6CDTi I put in 3L and it was a bit smoother when cold
    Cannock
    autodata lists 4 manual gearboxes for the v6 if your not sure ring vx and give them the reg and they should be able to tell you which gearbox it has.
    Quote Originally Posted by Celes View Post
    This would be the field remedy that corrects the poor lubrication on manufacture?
    However, I don't remember any mention of change to the amount of oil required
    Regular Member Jezzy's Avatar
    S.E
    It's a TIS Field Remedy - if the gearbox has 3.2 litres in it (which the first half of F40's did) and the customer complains of a crunch noise when changing from 1-2 (when cold) and 2-3 (when warm), then the remedy is to drain out all the oil and put 2.4 litres back in. The later F40s come from the factory with 2.4 litres.
    There is another one for "clutch slipping" traced to incorrect lubrication during manufacture
    Dealership applied that one when my clutch went earlier in the year
    Not sure if that includes adjusting the gearbox oil level as well
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    That's exactly what mine is doing at the moment
    S.E
    It's an easy fix
    http://www.vectra-c.com/forum/showthread.php?t=114193
  1. 1.9 cdti 120 how much oil should go in the M32 gearbox?
    By v33tra in forum Engine & Drivetrain
    Last Post: 9th February 2011, 01:18
  2. what gearbox does my cdti 150 have?
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2009, 17:10
  3. What gearbox in a 1.9 CDTI ?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2007, 00:21
how much gear oil for a s reg vectra to put in
