Results 1 to 3 of 3
Thread: Hello, my first thread ;) Vectra brake problem
    Jul 2010
    bucks uk
    Default Hello, my first thread ;) Vectra brake problem
    Well only just joined and hope someone can help me out with a problem...
    I had the front passenger side wheel bearing changed 2 weeks ago and straight away got a problem with the brakes. Never had an issue before this work was done... Most of the time the brakes work fine but now and then under heavy braking the car will pull very sharp to the right, feels like the front left passenger side brake is not working. It will do this a few times and then be fine again for a day. Took it back to the garage and they bled the brakes checked everything had been put back ok but found nothing wrong ??? Obviously there is an issue
    Thanks in advance, Ian
    PRESTON
    the only thing i can think of is that the piston in the caliper has started to stick. They will more than likely have removed the caliper to fit the bearing and maybe disturbed it. probably about £80 to £100 at the factors. I bet they will argue it was about to fail anway and there not responsible.
    Regular Member leonvectrac's Avatar
    south shields
    welcome to vectra-c !
  2. another brake thread
    By neverlandandy in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2010, 08:52
  3. Rear brake rewind tool thread pitch
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 13:03
  4. 02 Vectra C 2.2 Dti- Brake Pedal Problem
    By Devildriver in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2009, 15:29
