Thread: window seal rear quarterglass
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default window seal rear quarterglass
    Hi guys
    im about to replace my 2 rear quarter glass..
    but the seal on one of them is very compressed (and somewhat unflexible) in it present state..
    anyone know if you can get a new seal? (i dont want to use silicone, as a sealeant)
    Engine : 2.2 Direct
    just to show what seals im talking about...
    the bad seal
    The good seal
    Can that be bought somewhere?
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    could try main stealer, that prob only place for the actual Vx one,
    WGAF#5
    Ken, i doubt if VX/opel would sell the seal separate to the glass,
    phone one of thelocal windscreen fitting companies they generally have an excess of the sealer they use when replacing screens/windows etc in a tube and would probably give it to you as there paid for when replacing a full screen via insurers... its going to be the best sealant available
    Regular Member brigrif's Avatar
    South Shields
    Best bet is to use some sealant to bead around the apeture where the original foam seal is and fit the glass back. This is a common problem when removing the quarter glasses and the seal should really be replaced, but whether the dealers do it seperate is another thing.
    Engine : 2.2 Direct
    humm EPC dont have the seal (or atleast i dont know where to find it). I would prefeable to use the oem seal, as if i remove the windows its simpel.
    other wise i might be able, when removed one rear quarter, if not bad, i could reuse that, but then i would not be able to switch back again.
    South Shields
    If you have any windscreen/glazing companies round your area then ask them for some "damming strip" its the same stuff that is used on those quarter glasses and I use it at work. It's available in different thicknesses and is adhesive on one side too.
    South Shields
    pm me your address and I'll send you a few metres ken
    Engine : 2.2 Direct
    PM sent
  1. Rear door seal
    By conman in forum Bodywork & Interior
    Last Post: 20th February 2013, 19:14
  2. chrome window seal cleaner
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2009, 20:57
  3. Rubber seal on the front window...
    By Stevie-B in forum Bodywork & Interior
    Last Post: 13th May 2008, 14:37
replacing window seals vectra c
