Thread: Correcet oil for AF40 auto box
    salisbury
    Default Correcet oil for AF40 auto box
    Can someone let me know the CORRECT and BEST oil for the AF40 auto box.
    Haynes list GM 93 165 147 is this ok as i want to put the best in it.
    cheers
    Regular Member DaveW555's Avatar
    Cannock
    Thats just the vx part number doug, if you go to your motor factors and ask for ATF - AW1 that will be perfectly adequate and probably a damn sight cheaper than vx
    salisbury
    is that the same grade as vx or better. I dont mind what the cost is as i know the probs assciated with these boxes and dont want to put low grade oil in it.
    Cannock
    itll more than likely be the same or better just not in a vx bottle
    Regular Member kantimpalo's Avatar
    Feb 2007
    Spain
    You can use this:
    http://www.mobil.com/USA-English/Lub...l_ATF_3309.asp
    Is the same or best that the original.
  1. Auto box knowledge AF40?
    By NewcastleFalcon in forum Engine & Drivetrain
    Last Post: 22nd April 2017, 18:33
  2. Zafira B Help Please.. 1.9 CDTi Auto (AF40)
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 25th November 2012, 12:48
  3. filling AF40 Auto box oil. Help please!
    By andrew382 in forum Engine & Drivetrain
    Last Post: 18th August 2009, 19:20
