Results 1 to 3 of 3
Thread: auto gearbox big problem
    Jul 2010
    Birmingham
    Default auto gearbox big problem
    Hello to all, i got a 2003 vectra 2.2 petrol vectra with AF23 auto gearbox, my problem is i lost all drive forward and reverse, the manuel mode is not working also, i have changed the fluid it was brownish colour, but still no gears at all, some time it will move for a few seconds, then nothing at all, the engine just revs like it isin neutral. Any idea of the problem,
    one more thing every one wants know the solution to there faults ,but one actually cames back to say how they solved the fault. that just inconsiderate.
    Regular Member DaveW555's Avatar
    Cannock
    You say you changed the oil but did you change the filter? these can get blocked stopping the oil getting to the oil pump and this would give the symptoms you describe.
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    A friend of mine had a 2.2 with an auto box and lost drive as you have done. The oil cooler for it is in the radiator and it is apparently quite a common fault that they corrode and leak water into the oil. If you have had water in your auto box its highly likely that its goosed. Hope I'm wrong.
  1. 3.2 V6 auto gearbox problem!!!!!!!!!!
    By deltapapa in forum Engine & Drivetrain
    Last Post: 9th March 2012, 23:40
  2. 2.2 vectra c auto gearbox problem
    By Paddy in forum Engine & Drivetrain
    Last Post: 12th March 2011, 18:54
  3. 2.2 auto gearbox problem
    By renesis in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2010, 21:16
  4. Help please !! 2006 Auto gearbox problem
    By n1nlt in forum Engine & Drivetrain
    Last Post: 17th March 2010, 23:29
  5. Auto Gearbox Problem 2.2 SXI 52 plate
    By WeDesign in forum Engine & Drivetrain
    Last Post: 21st January 2008, 18:40
