Thread: Help this rattling is doing my tree in!!!
    Jul 2010
    castleford
    Default Help this rattling is doing my tree in!!!
    My vectra sri t100 has a right virtually constant rattle, its a metal sort of noise which is definitely coming from the rear wheels. thought it was suspension arm bushes so replaced them, which made no difference. then i found out that when i brake/handbrake while moving the noise stops. checked brake pads and copper slicked them up still no difference.
    just wondering if any one has any ideas apart from driving it into a tree !!!!!!!!!!!
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Sounds like the pad rattling in the caliper/carrier. Are the shims in place top and bottom? Are the pads a tight fit in the carrier?
    Jul 2010
    castleford
    dont think they had shims on. they were replaced before i bought the car. the pads were a tight fit in carrier though. can you buy shims from any motor parts place and how much do they cost??
    Jul 2010
    castleford
    checked shims they were on, so bought a new set of brake pads and noticed that they had a lil butterfly like spring on the piston side pad which holds the pad in the calliper properly. obviously mine hadn't got one on. smooth ride now!! buzzing
    cheers
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    No problem. Rattling brake pads can be a right irritating pain in the plums!
    May 2008
    manchester
    Hi Guys
    I have the exact same problem and its doing my head in.I have the little butterfly spring thing on the inside next to the piston.And the outside pad rattles real bad when going over bumps/rough surface.There is a tiny movement in it when parked up with the breaks off.its only on one side!!!! Help
    Staffs
    My vectra did exactly the same, the rattle was a loose pad. The spring had compressed too much and not 'sprung' back and it would always stop under braking. I had it off stretched the spring back and its nice a quiet now
    May 2008
    manchester
    Quote Originally Posted by IWC View Post
    i have a loose pad,only thing is its the outside one,the one next to the piston has a small spring to hold it,its the outside one on the rear thats doine my nut in!!!
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    mine click when brakein from a low speed any ideas please
  1. What Tree should I get ?
    By nibblitz in forum The 'Off Topic' room
    Last Post: 2nd March 2012, 20:19
  2. magic tree
    By baz2003uk in forum Detailing and Car Care Discussion
    Last Post: 1st June 2009, 23:41
  3. xmas tree
    By steeb82 in forum The 'Off Topic' room
    Last Post: 30th November 2008, 18:14
  4. Tree Sex!!!
    By SignumPhil in forum General Chat
    Last Post: 22nd April 2007, 19:05
  5. P155ed off tree
    By AJA in forum Comedy & Humour
    Last Post: 17th February 2006, 09:23
