Thread: cd30 convert to mp3?
    Regular Member Rab's Avatar
    Irvine
    Default cd30 convert to mp3?
    i have a cd30 stereo
    would like to upgrade to the cd30 mp3 so i have the aux port.
    do i need the mp3 headunit or can i convert to mp3 with the normal headunit?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    i'd be most interested myself if it's possible
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Check the how 2's. Im sure I saw a thread about adding a aux port to a stereo in there somewhere.
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    does the cd30 mp3 play mp3 cds or does just have an extra port?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Ah it was the CDR2005. How 2 is HERE
    Sep 2009
    swansea
    Trim : Club
    is there a way for the cd30 to play mp3's
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The basic CD30 only plays standard audio CD's
    The CD30 mp3, as it's name suggests, can play mp3's that have been burnt onto a CD
    The CD70 Navi can also play MP3's on a CD.
    Not so sure about the CDC40, but as this is the "Audio" upgrade head-unit, then I should think it does play MP3's on CD also.
    None of the radios before July 2007, will have any other form of Aux-in, however there is one european forum member who has modified some head-units (CD70 springs to mind) to provide aux-in capability.
    If you get a replacement head-unit from 2008 onward, then you are more likely to find an aux-in capable facility.
    On the pin-out label on the CD30, it does mention RSA (?) pins, but I have not found any explanation for what RSA stands for.
    This may or may not be for an Aux-In facility, as Vauxhall's TIS system states that the CD30 has connection capability for Aux-in.
    (but it does not explain how to go about it).
    Irvine
    so to be on the safe side i need a cd30 mp3 and then get an aux port put into it?
    if i could gaurantee my trip computer worked and i could reset them i would just get an aftermarket number.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    An easy cheat would be to get a Graphic or colour screen, and an aftermarket radio.
    The screens would be able to display all your computer functions, and an aftermarket radio will have better value for money than any Vauxhall unit.
    My friend from work bought a radio from Aldi for £50, it had bluetooth , mp3, SD card slot, USB and built in CD drive.
    He statedthat the built in blue tooth was actually clearer and better than his Parrot Kit.
    Also, if you have an aftermarket radio, then you don't necessarily need to have the display paired to the head-unit or the car, as long it isn't in safe mode.
    Just a little food for thought!!
  1. possible convert
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 19:52
  2. Hello from a convert again
    By WilliamLX in forum Introduce yourself.
    Last Post: 26th August 2010, 09:57
  3. A new VX Convert
    By Kapt Kaos in forum Introduce yourself.
    Last Post: 11th May 2009, 21:00
  4. Convert!
    By rogerp in forum Introduce yourself.
    Last Post: 30th April 2009, 17:49
  5. LR Convert
    By harveyg77 in forum Introduce yourself.
    Last Post: 29th July 2007, 00:21
cd 30 mp3
how to switch to mp3 on cd30
convert cd30 in cd30 mp3
opel zafira 2007 mp3 change
convert cd30 to mp3
can i play mp3 on my astra cd30 stereo
update your cd 30 without mp3 astra with
opel astra cd30 to mp3
convert vectra c radio
cd30 omzetten mp3
vauxhall zafira 2006 life cd 30 play mp3s
lågnivå cd30 vectra c
