Thread: Intermitant Problems Starting - Revs limited to 2K
    Jul 2010
    Caerphilly
    Default Intermitant Problems Starting - Revs limited to 2K
    Hi All,
    I'm hoping that this forum will prove as useful to me as it obviously has to so many others.
    I am having intermittent problems when starting my car, the car will start but when I try to accelerate I have no power if I just sit and rev the engine it will be limited to 2K Revs, if I stop and start the engine a number of times eventually I'll get full power and be able to drive. When the car start OK I can drive it normally and have no noticeable problems.
    Sometimes when I start the car it'll let me Rev up to 3.5K and if I then drive off the fault will clear and I will get full power and be able to drive normally. When I took the car into the local garage they plugged the computer in and could see an EGR fault and so have replaced this, they are now telling me that the linkage bar on the Induction Manifold is broken and that this is causing the problems but apparently that does not tie in with the description I give them about the limited Revs.
    I am also told that I should not be able to press the brake on my car and rev the engine, that the ECU should stop this from happening - Is that right?
    And that if the car dropped into limp mode (which is what I thought it was doing by limiting the revs to 2K) the car would not drop out of limp mode again until someone plugged a computer in and cleared it.
    Does anyone have any thoughts on what my problem could be? (besides a lack of money!) or any suggestions as to diagnostics that I could undertake?
    Thank for any advice.
    Dave
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what type of engine have you got?
    Regular Member pugs,signum's Avatar
    swansea
    If the link bar on the inlet manifold is off then there your problem!
    Mine came off and it had no go in it until turbo kicks in, changed inlet manifold (swirl valves) and all was fine after that!
    search for swirl valves n have a read!
    Jul 2010
    Caerphilly
    Quote Originally Posted by Caveman_nige View Post
    I've got the 1.9CDTI 150.
    (and no knowledge of cars at all really!)
    swansea
    not serprised your car is struggling as its getting on a bit now lol its 1.9cdti (150) and was first registered in 1954 lol
    only having a bit of fun dont mind me
    Jul 2010
    Caerphilly
    Quote Originally Posted by pugs,signum View Post
    Hmmmm yeah - what can I say I've tried to look after it. Ok it's a 54 plate actually registered 2004, I'm just pleased I got my name right in the profile.
    Jul 2010
    Caerphilly
    Thanks for the feedback - I've had a look at the swirl valves posts and it seems everyone talks about poor performance, admittedly my car is an automatic so perhaps it is hitting the car harder than manuals but is this the sort of problem that would clear itself and be as intermittent as I'm suffering from?
    N Ireland
    My swirl bar has been off the car for nearly 70000 miles and its only recently that I started to experience similar problems on startup and the odd time at round abouts where the engine would take a lifetime to get to 2000revs and then it would suddenly start to rev as normal ....is there a chance that the position of my swirl valves were in a sweet spot (open/closed/half open) and that could be why I never experienced any problems
    No doubt my inlet system is as gunked up as a gunked thing...so the build up may also have got to a critical level?? Can the inlet manifold be cleaned or is replacement the only way?
    120000 miles mostly A/B roads & Motorway driving mainly
  1. 1.8 revs stuck after starting, EM on!
    By GizmoGary in forum Engine & Drivetrain
    Last Post: 9th May 2012, 15:42
  2. Starting a Limited Company
    By the_wave_rider in forum The 'Off Topic' room
    Last Post: 14th March 2012, 17:12
  3. Limited Revs
    By Beridor in forum Engine & Drivetrain
    Last Post: 9th July 2010, 19:46
  4. intermitant starting problems
    By pward in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:05
  5. Limited revs and power down
    By Ste in forum Engine & Drivetrain
    Last Post: 24th November 2009, 11:59
