Thread: CD 70 Sat Nav Suddenly can't locate car!!
    West Midlands
    Default CD 70 Sat Nav Suddenly can't locate car!!
    I have 07 plate Signum Elite CDTI, used sat nav today to visit a new client, no problems.
    On return to car just pressed the "home" button to start navi. Got "please proceed to the planned route" command then told to turn right when I knew it should be left, so looked at map and position arrow had me placed about 100 yards away from actual position!
    I have taken CD out a & put it back in but it still not locating correct position. When driving it shows car in wrong position, so any navigation is impossible.
    Any ideas to what has happened?
    Mar 2007
    North East
    Sometimes get's it's knickers in a twist or it's a sign the aerial is going faulty, not a cheap replacement for the full aerial base, cheaper option is to get a "patch" GPS aerial with a fakra plug from ebay only about £10.
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    definately sounds like the aerial base signal amplifier is going belly up.
    I have patch aerials from e-bay in both my Cavalier (yes I know!!) and the wife's Vectra-c
    Both are fitted with CD70, and both locate immediately, all of the time, and are usually within about 20 feet. No problems with either aerial, even after about 5 years of usage.
    Only thing to bare in mind with patch aerials, is that they like to have line-of-sight exposure to the sky...especially through the wind-screen.
    The Cav one is velcro'd to the top of my dash near to my tax disc.
    The Vectra one is inside the grill panel in the centre of the air-vent on top of the dash (where the centre speaker can be fitted).
    Regular Member Exclusive BV's Avatar
    West Midlands
    Yeap defo the aerial.
    If you check how many satty's are being received at the present time (in the settings)
    I bet it will be 3 or less. (probably 1 or 2) hence the 100 yards offset in position.
    check the connections and stuff first though obviously
    West Midlands
    Thanks for the replies.
    Got in the car the following day and all is well
    Must have just thrown a wobbly or impending problems ahead, but absolutely back to pin point navi now
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Glad it's sorted
    Yep, sounds like a wobbly had been thrown !!
    Regular Member Jason123's Avatar
    Quote Originally Posted by Exclusive BV View Post
    How do you check how many sats are visible??
    West Midlands
    My mistake, does not look as if you can on these , Although the altitude accuracy is normally the first thing to degreade if the reception is poor.
    Vx state the tolerance for these units is 30m
    Mar 2007
    North East
    Think you get some info with the radio in test mode, can't remember exactly what though.
  1. i can't locate the power steering fluid
    By jamesuk in forum Troubleshooting
    Last Post: 19th August 2011, 10:47
  2. Locate Address By Phone Number
    By spennny in forum The 'Off Topic' room
    Last Post: 31st May 2011, 17:47
  3. Vectra SRI 2006 , holes to locate griffin badge??
    By stuartiwilson79 in forum Styling
    Last Post: 9th March 2011, 22:43
  4. Help Me Locate Speed Pulse
    By Ashg in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 23:17
  5. 2.2 Dti - No. 3 plug. How do I locate it?
    By Saggy in forum Engine & Drivetrain
    Last Post: 28th December 2008, 11:38
