Results 1 to 10 of 14
Thread: water pump
    telford
    Angry water pump
    took the car to vaux and told them i was having to put water in the thing ( i only got i 6mths a go from a stealer it has only coverd 19000 miles) thay rang me and said the water pump was at falt so thay replaced it has any of you guys had this and should i be worried is it the start of more things to cum
    PRESTON
    what engine is it bud? 19000 is low miles for a pump to fail, but its like anything, some will go early others later. When components are mass produced i guess its only natural that some will be better than others. Hand built by robots huh? I wouldnt worry, enjoy driving her and keep up the regular maintainance.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    there are bound to be a few parts in the bunch that fail early, these things happen.
    telford
    its a 1.8 vvt thought these was the best
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    nah ian they are absolutely f*****g s**t awful cars, you should have got a 2.2 direct like mine,no problems what so ever.
    Blantyre
    Water pumps hard to change ??
    Nov 2007
    telford,
    0n the 1.8? just remove timing belt and undo the three pump retaining bolts tap with a rubber mallet to release it from the block then remove.hth.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    water pump on a 1.8vvt is external and is easy to change..... there have been a few that have leaked early ........
    telford
    wot ever marty thay r good untill u get ur hands on them and proper fxxk them like the little festa that you killed ha ha ha
    Nov 2007
    telford,
    and u say u love me.lol
  1. water pump
    By GCusdin in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:16
  2. Water pump.
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 24th September 2012, 22:19
  3. New water pump due???
    By R33Leroy in forum Engine & Drivetrain
    Last Post: 1st April 2012, 21:27
  4. Water pump
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 18:55
  5. Water Pump 2.2
    By richpu in forum Engine & Drivetrain
    Last Post: 27th January 2009, 01:46
