Results 1 to 10 of 11
Thread: Bigger brake upgrade options 04 SRi 2.0 T
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Default Bigger brake upgrade options 04 SRi 2.0 T
    Just seeing what oprions I have preferably with the standard calipers, if any? Would the 308mm of the 2.6 GSi's fit?
    The Vectra B calipers are completely different and not compatible mate. Your options without changing the calipers are limited apart from fitting drilled or grooved discs/green stuff pads which would have a small difference but I haven't tried that so can't comment.
    Your main options are upgraded the setup to either the 314mm V6 brakes or the 345mm VXR ones. In either case you need to buy the full setup with calipers, carriers, discs and pads...
    Regular Member Jezzy's Avatar
    S.E
    Apr 2008
    suffolk
    Quote Originally Posted by Penfold101 View Post
    OK thanks. So if was able to get hold of the calipers I take it the carriers (where it bolts on to the strut) will also be needed? Out of interest, what size mine as standard?
    WGAF#5
    have you sorted your tubo issue yet mate ??
    Sheffield
    whilst on the subject im thinking about upgrading mine to the vxr ones... would i need new brake hoses or is it just the calipers and carries and disks e.t.c
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Yours are 302's mate. I upgraded mine to 314's on my old 2.0T after I remapped it, and they made a big difference .
    Regular Member david.aka.judas's Avatar
    Suffolk
    no - get these:
    http://www.regal-shop.co.uk/acatalog...nversions.html
    Quote Originally Posted by ROCKATANSKY View Post
    302's on the front, 292mm vented on the rears (biggest available, only upgrade are the VXR rears which are the same but painted blue...) In general the carriers will come with the calipers anyway mate, but it's always worth cheacking if you're buying them off ebay etc...
    Quote Originally Posted by turbosiggy View Post
    Hoses are the same mate, but if you're investing in the VXR's then for an extra 50 quid a set of braided hoses won't do you any harm...
    Apr 2008
    suffolk
    Not exactly. Kit is on back order from germany. They say middle of next week so when the garage that's doing it get it reckon it'll be a couple of hours so fingers crossed! But good news is that the dealer i got the car off has agreed the pro former that the garage sent to them. I spoke to torquingbhp earlier about a re-map so when it's done will be going over there
  1. Ccr 2006 upgrade options
    By wesleyneary in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2011, 20:17
  2. Phone Upgrade Options
    By RobW in forum General Chat
    Last Post: 17th March 2011, 18:24
  3. bigger disc/pad upgrade?
    By clembo38 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2010, 21:09
  4. brake options......
    By chris_20 in forum Handling & Braking
    Last Post: 25th September 2006, 19:07
