Thread: Anyone had to have a clutch master cylinder?
    Regular Member DaveW555's Avatar
    Cannock
    Default Anyone had to have a clutch master cylinder?
    As above really, I've done everything else on the clutch system but first thing in the morning the clutch has sunk, there's no leaks that I can find but it is like its getting air in somewhere, the only thing that I can put it down to now is the master cylinder so just wondered if anyone else has had one go?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Dave
    VX have had problems with clutch hydraulics,they now bleed system under pressure with clutch pedal held down,after bleeding the pedal is pulled up slowly,repeat 4 times,
    Cannock
    Hmmm never heard of that method before, sounds like it might do the trick tho, I'll give it a go and see wat happens, cheers
    Cannock
    Tried that method but no fluid came out of the master cylinder and lost me my pedal all together new master cylinder fitted (£72) and like new again happy days til the next thing lol and happy mrs dave as she can now drive it again, dunno if thats a or a yet, I suppose I'll find out next time she hits something lol
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    sounds the same as what ive got wrong
    drawing air in with no noticable leak
    i bled it up and held pressure on the clutch pedal and it sank slowly
    done it a bit to hard and snapped the bloomin plastic pushrod so a master is about to be on order anyway - removed the clutch master cylinder and it was damp under the boot so heres hoping thats the only cause of my pedal losing pressure.
    if it persists then its concentric slave cylinder time along with clutch
    i got a quote from mr clutch autocentre and they want over £1500 to do the job cause they want to change the dmf aswell. -- nothing wrong with the dmf of clutch.
    i asked them what price is the dmf and they said 954 quid or something WTF ive seen them half that price
    and they price the csc at 160 quid again ive seen them half that price.
    think ill be doing it myself if it comes to it
    Regular Member clairey83's Avatar
    Nov 2011
    Dumfriesshire
    Engine : 1.9cdti
    Mileage : 155000 :o
    My master cylinder went. I've nae idea pretty much most of what you said haha. But one day my clutch just broke, couldn't get into any gears and it turned out the master cylinder was the problem. £25 for a second hand one (I'm poorer than poor :-/) and it was good as new. Never had any bother since. Well wi my clutch anyway :-/ ha. Engine needs stripped in Easter hols coz it's going through oil pretty bad! I have the worst luck wi vauxhalls...yet still loyal to them!!
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    I had it changed on mine, the pedal just dropped to the floor and wouldn't come back up, they changed the master but it wasn't the problem so ended up with a new dmf and clutch as it was rattling quite badly, cost £800 for all 3, I must admit though the problem Is still there a little, sometimes the biting point drops and the pedal dosent come back to the top, you have to flick it back up with your toe.
    Mar 2012
    paisley
    well changed master cylinder with a brand new one and it wasnt the issue
    had to change the csc
    all solved
    it must draw air in through there as i cleaned and checked al lines for leaks
    inside bellhousing was damp but not soaked
    old unit was the original gm with 88k miles
    the bearing had play
    and the hydraulic telescopic bit had side thrust / worn plastig guide bushing.
    Mar 2012
    paisley
    3 weeks on and its still perfecto
    couple of rubbish phone pics at about 3 am saturday morning 3 weeks ago
    took about 10 hours and was a mission
  1. 2.0dti clutch master cylinder
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 00:47
  2. Clutch + DMF + master + slave cylinder
    By Bobsta in forum Engine & Drivetrain
    Last Post: 9th November 2012, 23:33
  3. Vectra C Clutch / master Cylinder
    By k34sty in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 09:19
  4. Master cylinder.
    By fluffsri in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2009, 17:51
  5. Master Cylinder
    By parsco in forum Handling & Braking
    Last Post: 22nd January 2009, 11:38
vectra clutch master cylinder
vectra c clutch master cylinder
vauxhall vectra c clutch master cylinder
vauxhall vectra master cylinder
