Results 1 to 10 of 25
Thread: Please help - still sluggish 150sri
    Retford
    Unhappy Please help - still sluggish 150sri
    Hi all,
    I had a new manifold and actuator fitted yesterday, my 06 sri 1.9cdti 150 is still really sluggish under where the turbo kicks in the engine feels cleaner and a bit more smooth now thats replaced but there still feels like somethings holding it back
    he replaced the manifold, cleaned the egr and cleaned the boost sensor.
    anyone any other ideas what could be wrong please, before yesterday i noticed when the weathers damp and rainy the car drives like a dream but when its warm and dry its like a huge slug
    i did order a replacement airflow sensor from ebay but had 2 now and both cause engine management light and limp mode, but didnt realise they are not proper bosch parts but replacements, so ive asked for my money back. i found another supplier of bosch one for about £80 wonder if thats the fault
    im running out of ideas
    any advice please?
    Chris
    Birmingham
    Hi mate,
    I had the sluggish under 2000rpm issue, in fact it wouldnt move, and in the end I got a Brand New EGR Valve on it and it worked a treat, much to my surprise.
    I Had cleaned out about 3 EGR Valve's fitted about 5 different one's and even a Brand New one off the bay of E, but until the New one from Vx was fitted, the problem remained!
    I know its another cost but if you can get 100% confirmation that your EGR Valve is scuppered, you will find that its the best £100 you will spend!
    Hope this helps.
    Check my threads, I had LOADS of issues!
    Best of luck pal, I feel your pain mate, I really do!
    Thanks, G.
    Bye bye Vec B
    - Hello Siggy!
    Retford
    Hi Vaux-Man-G, Thanks for your help !
    I should have put in my posts - it had a new EGR valve within the last year, infact its only done 5k this year
    Birmingham
    Oh......
    Have you checked the boost sensor?
    Bye bye Vec B
    - Hello Siggy!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Temporarily blank the EGR, just to see if this is the cause, its amazing how this causes these problems, nearly new or not.
    Birmingham
    Or disconnect the bleeder as I did....which also resulted in a return of low end power.
    Bye bye Vec B
    - Hello Siggy!
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by Vaux-Man-G View Post
    That won't always work though.
    Retford
    Hi guys,
    Can i unplug the connector from the egr valve to test it? or would u recommend taking the 4 bolts out and putting something behind it like cardboard as a temp block?
    Cheers for your help
    Retford
    guys - you dont think its worth me buying a new airflow meter and if i can find one a replacement boost sensor? i found a supplier for a bosch airflow meter for £85 inc delivery
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    i reckon it could be split boost vacuum pipes check the sticky thread on here i replaced mine with clear plastic ones and my car flys now from 1500rpm just because of a perished pipe
    sticky is top of this section
  1. 07 SRi Sluggish
    By obews in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 20:30
  2. Superchipping Vectra 1.9CDTI 150SRI
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 22:15
  3. Sluggish again
    By durham4416 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:20
  4. sluggish
    By chrosty in forum Diesel Engine related
    Last Post: 29th December 2010, 23:55
  5. sluggish 1.9 cdt
    By thommo in forum Introduce yourself.
    Last Post: 16th March 2010, 14:57
