Thread: Blanking gasket ?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Blanking gasket ?
    Hi
    Can anyone tell me the correct blanking gasket for the EGR. For a 120 8v if I replace them with the blanking ones can I do this from the silver pipe with two oval gaskets in or do I need to blank it off from the black bit which should have a square gasket in I think.
    Any part number or website would be good
    salisbury
    is it a 1.9 cdti 120 ps?
    120 8v m8
    Central Scotland
    Disconnect the wiring plug and undo the two torex bolts and it splits in half..
    It's a funny shaped gasket with two holes about the size of a 10 pence, blank one off to stop the gas flow, the other should be open to allow the valve to move and tell the ECM it's working properly, or, the EGR operation can be tech 2'd out the ECM if need be.
    *ahem* I used a Budweiser can *ahem*
    salisbury
    fiat gaskets,
    120 8v - 0055226183
    150 16v - 0055225287
    salisbury
    pics of gaskets, i have used both with no probs.
    Regular Member DaveW555's Avatar
    Cannock
    Coke can works pretty well and its free lol
    EVERYWHERE
    Coke can works fine....for a while.
    Even less good if you've put holes in it.
    The last thing you want is bits of aluminium finding its way into the combustion chambers etc.
    Thanks all
  1. EPC, gasket P/N
    By lmantuano in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 14:38
  2. egr gasket
    By silky in forum Engine & Drivetrain
    Last Post: 7th October 2012, 13:15
  3. Pre cat gasket
    By johnnyboy1985 in forum Diesel Engine related
    Last Post: 1st March 2011, 00:10
  4. EGR blanking plate & gasket
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2008, 17:48
